Tanix TX9 Pro vs Tanix TX92 or Vorke Z6???
Originally posted by clifforama View PostThanks, Guest. I'm also ordering a Vorke Z6.
Originally posted by RASTAVIPER View PostMaybe you have to check at the Vorke plus topic.
Unleashed by ONEPLUS 3T rooted
Perhaps you should look in Tanix threads as you bought one?
Geekbuying 11.11 Flash Deal is on now for Vorke Z6 3GB/32GB. $82.72 CAD - $6.55 with coupon PAYPAL. That's about $60 USD. It's probably a little cheaper if paying in USD directly.
(FWIW, my order status still says unpaid even though I paid. According to online chat, confirmations are delayed due to 11.11 promo.)
Unfortunately, Canada Post delays for items from China are horrible -- I might not see the box for up to 6 months. I may just order one from Amazon with free two-day shipping. At significantly higher price, though.
Originally posted by tombraga
Why should I look for plus version if I don't buy it. Also I am writing here in my own thread which I opened.
So in your case, instead of having that attitude towards me that I am trying to suggest you a solution, you should be thankful.
Ok mate?
Originally posted by clifforama View PostGeekbuying 11.11 Flash Deal is on now for Vorke Z6 3GB/32GB. $82.72 CAD - $6.55 with coupon PAYPAL. That's about $60 USD. It's probably a little cheaper if paying in USD directly.
Originally posted by Mis3 View Post
Hope you received the Z6. How do you like the box?
I'm pretty happy with the box. I'm using Magendanz' Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROM (Android 7.1). I don't use Netflix or anything that requires Widefine L1. No regrets so far.
Hello all,
i've just received my Tanix TX92, upon inspecting this new tv box a model sticker underneath it says "TX92-LP". Does anyone have an idea what model is this ? I asked the vendor about this issue but they gave me an uncertain answer. It's a 3G/32G Version, is this a lower end model ? or is this with DDR3 instead of DDR4? I remember seeing members mentioned in other posts about Vorke Z6 carries two specs : TX92-A & TX92-B. Not sure how Tanix define their specs.
Any advises will be greatly appreciated.
ThanksLast edited by larryman; 05 June 2018, 22:40.
Originally posted by lyubodelev View Post
LPDDR3. Open the box to see what is the WiFi chipset. If it is 9377, you are lucky (you will be able to install SCV7A).
Thanks lyubodelev. I didn't bother pile opening the box as i have decided to return it. I believe that it is a LPDDR3 version, but my vendor insisted that is a DDR4 version.
TX92-A(B) - DDR4
TX92-LP-A(B)_(V1.0) - LPDDR3.
Now the WiFi chipset may also be changed from 9377 to 6255...Last edited by lyubodelev; 06 June 2018, 11:12.
There are currently 2173 users online. 0 members and 2173 guests.
