OTT M8S+ bricked. Boots only to Amlogic logo. Been spending a lot of time trying to unbrick. Help would be much appreciated.
I usually can figure things out for myself but been reading lots of mixed articles regarding unbricking my dads M8S+. After much research I'm at a complete loss as to the process I can try to unbrick the device and where to download the needed files. Can anyone offer some guidance?Tags: None
I've been trying to unbrick an M8S with very little results. At this stage, I have so many wasted ours into this chinese piece of shit I'm ready to cut my losses and buy a real box with support like the nvidia shield.
Anyway,
Do you currently have any lights on when you boot?
There are 2 pieces of software that you generally use to unbrick: USB_burning_tool and SD_Card_Maker
You can google and find both of those easily.
I wasn't able to get my device recognized in USB_Burning_tool so I've been trying SD Card maker.
You might also need to jump pin 29-30 on your NAND to get it to write if you're having issues with USB Burning tool
There are currently 3024 users online. 0 members and 3024 guests.
