[OTA UPDATE Stock ] 20171103 MECOOL M8S PRO AMLOGIC S912 ANDROID 7.1 TV BOX FIRMWARE
    Any updates on this ??
    Fun,Learning and Mutual Respect ......Its Good to Share
      Originally posted by shaft65 View Post
      Hi guys.
      Flashed the new .img yesterday. Not to my liking so I soon flashed back
      In this build, the Android bar at the bottom is no more and I couldn't see any way of recovering it in Settings. Also there is a new version of Play Store that couldn't find my VPN app, or Gmail, so no good for me. Am I missing something? Or has anyone else found this with the new build?
      No big deal as I like to tinker and get more flashing experience
      Sir this is my first post.. Yesterday I flashed Nexus rome to mecool m8s pro. Now i want to back to stock...but twrp is not working....Two times I was able to boot in to recovery and restored successfully. But mecool stucked in boot logo.Please help me if you can. I use it lot for browsing mainly. Status bar is must for me.
        Hi bichitrax.
        Sorry I have only just seen your post. If you have not fixed your issue yet, I would ask Magendanz. He is far more experienced than I am and I cannot really remember what I did right now!
          hi
          i tried to update MY M8S PRO and i got the following message
            Hi, I'm running stock and get an error 7 message. This occurs when trying to using the OTA tool with the stock recovery and when booting TWRP 3.0.2.0 from microsd. The log file is as follows:
            Installing zip file '/sdcard/Download/M8S_PRO-ota-20171030.162112.V0619-fixed.zip'
            Checking for MD5 file...
            Skipping MD5 check: no MD5 file found
            I:Zip does not contain SELinux file_contexts file in its root.
            I:Legacy property environment initialized.
            *** Install Amlogic firmware update ***
            *** Install Amlogic firmware update ***- Confirming target device...
            Found: M8S PRO, M8S PRO-userdebug 7.1.1 NMF26Q 20170519.102643.V0321
            script aborted: E3004: This update package is intended only for the M8S Pro.
            E:unknown command [log]
            Updater process ended with ERROR: 7
            I:Legacy property environment disabled.
            Error installing zip file '/sdcard/Download/M8S_PRO-ota-20171030.162112.V0619-fixed.zip'
              is this new firmware or not ?
              Hey guys, Glad to share the firmware for MECOOL M8S PRO 3GB/32GB and 2GB/16GB TV Box PC Flash Firmware Flash guide, please refer to: https://www.geekbuying.com/geekgiz/index.php/2016/02/20/android-tv-boxes-flash-tutorials-tool/ Have fun! Aug 22, 2018sharon […]
                Good find paiktaras69. I'm just downloading it now. Did it flash okay?
                  Ι don't know how. I have twrp recovery and root via sure. Can I flashing from twrp?
                  sent from my 1+3T
                    I would not flash it unless you understand Cantonese! :-) I could not get it off of these screens: Maybe Magendanz or somebody else can figure out how to use it.
                    Click image for larger version  Name:	20180902_193449.jpg Views:	1 Size:	109.2 KB ID:	743100 Click image for larger version
                      is this new ota firmware or not ?
                      M8S_PRO-ota-20180806.105401.V0213.zip
                      https://4pda.ru/forum/lofiversion/in...1161-5140.html
                        A followup: The firmware shipped with the device (off **** Australia) had M8S PRO_XGO as the name. I edited this using a buildprop editor to remove underscore XGO. I then flashed the Nexus ROM via OTA.
                        (In case anyone else has the _XGO firmware!)
                          I want to know if it is possible to Switch from SuperSU to Magisk and if so which is the most correct way ? For example ......this tutorial it is safe ? https://www.androidexplained.com/switch-supersu-magisk/
                            you know what helps the following zip ? (post 5368 ) https://4pda.ru/forum/index.php?show...811161&st=5360
                              What is the correct ROM for the M8S pro L version LS?
                                Originally posted by trebor View Post
                                As Found
                                Glad to share the firmware for MECOOL M8S PRO TV Box
                                OTA Update Firmware
                                File Name: M8S_PRO-ota-20171030.162112.V0619
                                Source: blog.geekbuying
                                anyone with L version box tried? will it fix the wifi & bt problem?
