ROM wont 'stick'
    ROM wont 'stick'
    I am update 2 S812 boxes and the firmware works perfectly, until I reboot. I erased and formatted EVERYTHING before I applied them. I booted using TWRP, wiped everything, installed the .zip and everything boots up. The moment I remove the SD card it either does not boot or goes to the old image.
    What am I doing wrong?
