Firmware U2C Z-Super Amlogic S912 3GbRAM 32ROM - HELP can not FIND
Hi Guys,
I have the same problem. Installed SuperSU and got stick on boot screen.
I then tried a reset but it doesn't work.
Unfortunately I had previously done a factory reset and hadn't re-enabled the USB debugging so my PC cant see the TV box
If anyone has solved this it would be great to get an answer?
Regards
Oblique
Originally posted by mcdave View PostThanks for the link. I already contacted U2C thru Amazon Ca and have a reply. They sent me the zip files to use the upgrade option assuming that you can either use the backup/upgrade in the setup or enter the recovery mode and link to the files from there. I can't do either. I have a grey screen when I power on...that's it. I did manage to get my computer to recognize the box in the USB burning tool. I had to short nand pins 17 & 18 on the Samsung chip, then voila.
I have attached the link to the firmware website for anyone that needs it. I have also requested the img file I need so hopefully I can revive this box with USB burn tool.
Keep you posted....
https://drive.google.com/open?id=1W6...2eLXCQuYkLoVWk zip file
https://drive.google.com/file/d/1F4u...p1WxJbDAK/view img file
Note to Admins: Pls post firmware in appropriate place..thks
U2C X Super Android 7.1 TV Box
U2C Android TV BOX 3gb Ram Hardware specification:
CPU:Amlogic S912 Octa core ARM Cortex-A53 [email protected]
GPU:ARM Mali-T820MP3 GPU up to 750MHz
RAM:3G DDRIII
ROM:32G eMMC
DC In: DC 5V/2A
USB Host:3 High speed USB 2.0 port and 1 OTG port,support U disk and USB HDD
TF Card Reader:Maximum Support: 128G(Micro SD Card)
Lan:1000M Gigabit RJ-45
Wifi:802.11 b/g/ AC(2.4G+5G)
BT:BT 4.1
AV In:AV(3 in 1) port
SPDIF:Optical SPDIF interface
Power Indicator:Power On/Off:Blue/Red
LED Display:White light digital display,Show time and device connecting information(Wifi/BT/Lan/AV/HD/SPDIF)
Software information:
O.S.:Android 7.1
Decoder Formats:4K, H.265, MPEG1/2/4, H.264, HD AVC/VC-1, RM/RMVB, Xvid/DivX3/4/5/6, Real Video 8/9/10
Video Formats:4K@60fps, H.265, AVI, H.264, VC-1, MPEG-2, MPEG-4, DIVD/DIVX, Real8/9/10, RM,RMVB, PMP, FLV, MP4, M4V, VOB, WMV, 3GP, MKV
Music Format:MP1, MP2, MP3, WMA, OGG, AAC, M4A, FLAC, APE, AMR, RA, WAV
Photo Format:JPEG/BMP/GIF/PNG/TIFF
DLNA: DLNA files sharing
Languages:English/French/German/Spanish/Italian etc. 24 languages
App Functions:Google play store,Amazon alexa,Netflix,Youtube,Facebook,Twitter,Online movies,etc.
Mouse/ Keyboard:Support mouse and keyboard via USB;Support 2.4GHz wireless mouse and keyboard via 2.4GHz USB dongle
Other feature:Free Internet searching,many kinds of games,etc.
U2C sent me 20190919.img files I want to use.
Hey guys, I know it's been years since this thread was created, but I was wondering if anybody might have the full .img for this product? My device is bricked so I need the full .img and not the OTA version in order to recover. The U2C folks have since left Amazon so I can't reach out to them. Can somebody that has this device backup their .img and upload it somewhere? I'd appreciate it so very much!!
I have the S912 Z Super 3GB 32GB version
Steve
Originally posted by sdemiere View PostHey guys, I know it's been years since this thread was created, but I was wondering if anybody might have the full .img for this product? My device is bricked so I need the full .img and not the OTA version in order to recover. The U2C folks have since left Amazon so I can't reach out to them. Can somebody that has this device backup their .img and upload it somewhere? I'd appreciate it so very much!!
Steve
i know it is stupid , but think you will find no new stock.img for your Box , only thing you can
try is Slimbox , Aidain , ATVExperience , Customroms for your type of CPU & Wifichip ,
otherwise buy a new one with better Support but this is not really simple , even Ugoos
has to learn better Support , there Brand TOX is not bad and a bit cheaper but Support
i dont know ,
nearly forgot you can try Supercelerons Roms for S912 too , but look for the right RAM
Version ,
further good luck / gefattern
HI ,
i dont know ,
I am not looking for anything new, I am just looking for the stock img file for this device so I can get it running again. Somehow my root access got messed up and trying to fix it, I bricked it using the OTA files that were listed in this thread earlier, so now that I am stuck with only the AMLogic Burning tool, I have to have the full img. I do have an exact duplicate of this box here, but I have no idea how to "clone" it or build a working img file from it. Would you happen to have any suggestion?
I hate to buy a new box, this one works perfectly for everything that I do and a newer box doesn't offer me anything more than the fact it should work out of the box whereas if I can just get the stock img for this device, I am sure I can get it back to how it was...
Steve
Hello Gefattern, thanks for your response.
Steve
i think you looked not good , or is his second Link not a IMG File , as i see above ,
did you tried it ??? it is still there , a rar File , download unrar it .
greetings / gefattern
Hi ,
Steve
Yes, I did get it, both files are the OTA version and not the full IMG. OTA works only when you can boot into recovery mode, which I cannot. I can only get my PC to recognizei the device via USB and the AMLogic USB Burning Tool sees it, I just need a good copy of the full stock image and I was hoping somebody on this thread that has the U2C 3/32 S912 device might have it to share for me...
Steve
look here , found with one search
Poison ROM Introduction Welcome to the Poison ROM thread. As promised, we're delivering a stunning quality ROM to the S912 community. Even though it was originally made for the T95Z, it may or may not work on other S912 Devices as well...
Originally posted by gefattern View PostHi sdemiere ,
read the last post number 2340 ,
I did find that myself yesterday and it's an OTA version that I can't do anything with, unfortunately...
Again, my thanks for taking the time and trying to help, it's appreciated more than you know!!
Steve
Hello Gefattern, thanks again!
Steve
for sure NOT , the Poison Rom must be a full .img File , otherwise all the others could not flash it
on all the different Devices , and this Guy reported that it works well on his U2C Boxes ,
You not Understand it , FIRST READ before you write BullshitLast edited by gefattern; 19 February 2024, 22:52.
There are currently 2303 users online. 3 members and 2300 guests.
