Thanks,
ROM Backup before you start
Okay - not trying to hijack this - but simple question? Before I flash this on a new box - how do I back up the current ROM? I booted with the toothpick and can get to that screen but there is no backup option. Inside the current ROM I have gone through a backup - but I have a suspicion that is not the "just in case" backup that I am looking for. Sorry for the question but hope someone can help.
Thanks,Tags: None
Ok please - can someone point me in the right direction?
I downloaded TWRP. Poked around there - but didn't see the easy answer.
I can boot into the standard Android recovery environment - but no backup
I have run the "Backup" inside Android but when I go into the other box and try to "Restore" it takes only about 10 seconds and nothing really happens
I can boot into the USB Burn tool and write a new ROM.
I just want some more tips on backing up and copying saved backups to a new box.
Thanks in advance
Originally posted by VoidnWarranties View PostOk please - can someone point me in the right direction?
Thanks in advance
looks like you ask before somewhere else , if , please give Link , if needed i can
move them together ,
so you want to restore the Backup of the One on the other , do you have root ??? ,
are the Boxes the same ??? do you have TWRP ??? installing did not work ??? ,
is it a .img or .zip File ??? , please answer to guide you the right Way , hopefully .
TWRP is not the only Way to do .
greetings / gefattern
Hi - I can answer my own question here now. The missing steps for TWRP that I couldn't find are all in this video
Simple really - just couldn't find it.
Now I can boot to TWRP and made a full backup. Hopefully I won't need it but feels good just to have it.
Instructions and various versions of TWRP are here in Freaktab: http://freaktab.com/forum/tv-player-...mlogic-devices
And yes - I did post this same question here: http://freaktab.com/forum/tv-player-...529#post683529
Maybe just delete that one?
Thanks,Last edited by VoidnWarranties; 21 November 2017, 01:57.
There are currently 1976 users online. 1 members and 1975 guests.
