Any Android 7 Nougat ROM for q200 boards?
    I bought a Sunvell T95U Pro (clone?) with q200 board and AP6335 (SM6335?) chip. I was hoping to use Guest's Beelink GT1 Nano Nexus ROM, but since that's for q201 boards, I don't want to risk it.
    So, are there any Nougat ROMs that work with q200 boards? (With support for the AP6335, if possible.)
    Thanks.
    Thanks.
    q200 is andriod 6.0 project.
    q201 is android 7.1 project.
      Is that set in stone? Because, for example, I know the p200_2G (for S905) came with Android 5, but there was at least one subsequent upgrade to Android 6. Specifically, the Ugoos AM1, whose firmware I was able to successfully flash on to my Beelink Mini MX-G (http://freaktab.com/forum/tv-player-...200_2g-devices).
      I was hoping for a similar upgrade for my S912 q200 box.
        It looks like a 7.1 Nougat ROM for the T95U Pro has surfaced:
        http://freaktab.com/forum/tv-player-...354#post692354
        I haven't tried it, and probably won't since I've given away the box.
        Update: This is not for q200 boards. I extracted the .img using AML Customization Tool, and it appears to be for q201_3GB. I guess there are variants of the T95U Pro that use different board and memory configuration from mine.
          Yes,The 912 new version fw is base to android 7.1.2.
