Does anyone know how to format the 2,5" harddrive for the Beelink Sea 1?? I have tried a couple of ways but I cant get the player to find the drive? Anyone got it to work?
How to format internal Harddrive for the Beelink Sea 1??
yup have a 500gb fitted to mine, you'll need to format the hard drive in a PC first, i used fat32 and the drive popped straight up on android
first time you use it it asks if you want to add it as system or as a shared/portable drive, i opted for shared as then it can be removed later on for file transfers on other computers
if you can't format it due to not having a PC then i'd take it to your nearest independent computer repair shop and ask them to format it for you as fat32,
i doubt they will charge much as it takes minutes and is a doddle to do
There are currently 2577 users online. 0 members and 2577 guests.
