Newbie question - Upgrade A912
    Hello,
    I would like to get Android TV on my current box which is an Beelink GT1 A912 - 6.0.1 - GT1_113M0
    I read one topic that explain that I cannot update to Android 7.1
    FIrst i would like to put stock Android and then install Android TV.
    For sure, i cannot upgrade with OTA anymore.
    When I try to upgrade with SD card with the pin method, the box freeze on the Beelink logo....
    Is there a way or should i buy another box ?
    Thank you by advance for my newbie's question..
    Originally posted by Scinor View Post
    Hello,
    buy male to male USB cable and flash with burntool from pc/laptop
      Hi ,
      no need to buy a new one , restore the old with flashing a new Rom maybe CustomRom from here ???
      good luck / greetings / gefattern
