Magicsee C300 Android 6 Amlogic S905D 2GB/16GB WIFI, LAN DVB-T2/S2 DVB-C BT
    Click image for larger version  Name:	geekbuying-Magicsee-C300-Amlogic-S905D-2GB-16GB-TV-BOX--461831-.jpg Views:	1 Size:	155.8 KB ID:	684402
    Magicsee C300 is based on the Android 6 OS, with high speed and smooth, designed to turn your regular TV into a smart one.
    Powered by an Amlogic S905D 64-bit Qcta-core ARM Cortex-A53 CPU, it is runs at up to 2 GHz. On the graphics front, Magicsee C300 sports an Penta Mali-450 for vivid and clear image display.
    Penta-core ARM Mali-450, a separate graphics processor dedicated to accelerate the creation of images to be outputted to a display, is structured around processing large blocks of data in parallel.
    It boasts DDR3 2GB RAM, and eMMC 16GB Flash, advantageous in performance, security and reliability, ascribing to the eMMC memory, ultimately delivering a richer end-user experience.
    IEEE 802.11ac, one of the wireless networking standards in 802.11 family, is developed in the IEEE Standards Association process for the purpose of high-throughput wireless local area networks (WLANs) on the 5 GHz band.
    DVB-T2 DVB-S2 DVB-C
    DVB-T2, the world’s most advanced DTT system, offers more robustness, flexibility and at least 50% more efficiency than any other DTT system. It supports SD, HD, UHD, mobile TV, or any combination thereof.
    A Brief Introduction of DVB Standards:
    • DVB = Digital Video Broadcast
    • DVB - T = T for Terrestrial, that means you pick up the signals with a terrestrial aerial.
    • DVB -S = S for Satellite, you pick up the signal from a satellite dish.
    • DVB - C = C for Cable, a card like this can get signals from a cable fed system.
    Magicsee
    Thanks to Magicsee we can have a look at the
    Magicsee C300 Android 7.1 Amlogic S905D 2GB/16GB WIFI, LAN DVB-T2/S2 DVB-C BT
    Brand: Magicsee
    Core: Quad Core
    CPU: ARM Cortex-A53
    GPU: Mali-450
    Max. Extended Capacity: TF card up to 64GB (not included)
    Model: C300
    RAM: 2G RAM
    RAM Type: DDR3L
    ROM: 16G ROM
    System: Android 6.0
    Type: TV Box
    Processor: Amlogic S905D
    Audio format: AAC,APE,DDP,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Video format: 4K
    Support 5.1 Surround Sound Output: Yes
    Language: English,Germany,Japanese,Simplified Chinese
    Power Supply: Charge Adapter 12v 1.5 amps
    External Subtitle Supported: Yes
    HDMI Function: HDCP
    Power Consumption.: 2W
    DVD Support: Yes
    HDMI Version: 2.0
    RJ45 Port Speed: 100M
    System Bit: 32Bit
    Power Type: External Power Adapter Mode
    Package size (L x W x H): 23.50 x 13.50 x 7.00 cm / 9.25 x 5.31 x 2.76 inches
    Package weight: 0.5200 kg
    Product size (L x W x H): 14.80 x 12.00 x 3.30 cm / 5.83 x 4.72 x 1.3 inches
    Product weight: 0.1950 kg
    Package Contents: 1 x TV Box, 1 x Remote Control, 1 x Power Adapter, 1 x HDMI Cable, 1 x English User Manual
    Lets see what we have:
    The Box
    What's in the box
    Ports
    Remote
    Remove the top
    Remove PCB from Base
    A Short Video first start.
    Magicsee
      Today testing of Android A7 release....
      More to come...
        I bought it, android v6.
        1. its dvb-s2 tuner Not so well, low quality tuner.
        2. SD channel quality bad- HD so so.
        3. channel transitions are slow on dvb-s tuner.
        4. android v6 not stable:
          • sometimes it restarts for no reason after first reboot,
          • some app give error(not responsive-wait-stop) first load.
          • it restarts when I press the home button on the remote control .
        i wait android v7.
          Been awhile and have been waiting for the New A7 release
          Today it has happened so we can have a Closer look at the Android side of things first.
          Then DTV so far both looking pretty good I find.
          Startup all good with Android 7, Setup, Login to Google, Play store Apps etc
          Upper Notification and Lower Task bars are available
          At this Stage No Root Access
          All Moved along pretty smooth and no Problems
          No Major heat problems Hight 70'S when pushed with testing
          Lets have a look at what we have...
          UI and Installed Apps
          System Information
          DRM Info L3
          CPU-Z
          Ram and Storage Truth
          GeekBench CPU More Info > http://browser.geekbench.com/v4/cpu/6784661
          Geekbench Compute
          A1 SD Bench
          Looking pretty good, no major problems seems as it should.
            DTV side of things,
            I only have DVB/T to test and show and all happened pretty smooth I found
            No major problems, just learning what key on remote does what etc so all Good.
            Run the DTV APP and we get
            Pick Mode required
            Pick location
            Auto Or manual Tune
            Bits here in Manual I dont full understand so I went with Auto
            After awhile maybe 3~5 minutes I could see I had all channels in then hit Escape to stop
            All Channels scanned and looking ok,
            Screen cap does not Capture TV that is shown so far that I have found
            All Channels in and looking good HD and SD,
            A slight sync with Audio/Video for 1 or 2 seconds if that when you change channel
            But once locked in no problems found,
            Running around 90% Sig and Quality helps to have a good Antenna for FTA TV.
              Looks ok for the price & nice to see its been updated to android 7
                As mentioned where you see Black, TV image is showing locally, No TV screencap
                Menu on remote gives you all the actions for settings PVR etc
                Program Manage
                Add Favorites etc
                7 Day EPG
                PVR Manager reads what you have recorded on USB Stick
                When you select record queries amount of minutes you require to record.
                A recorded bit of TV music replace due to the circle C
                  Cool looking Box do you know if you can get softcams working on this?
                  • trebor
                    trebor commented
                    Editing a comment
                    New GC and CC are supported...
                    Code entered at TV SETUP
                  i have this box ... no ota android 7 ... and no update on magicsee site
                    Android 7.1.2 firmware
                    First release:
                      First release:
                      thanks brother
                        How did you flash the new Android 7.1.2 firmware?
                          USB Burning tool, and A to A: cable
                            Firmware update c300 905d
                            https://mega.nz/#!gax12BoC!cgt8E8jdI...OxPYzFFiJY1uEI
                            File name: C300_S905D_android_7.1_20180309_upgrade_package
                            changelog:
                            1:Update the CCcam & Newcam version
                            2:Multi satellites blind scan
                            3:HD channel sign(On channel list)
                            4:Channel sort array(a to z,TP,Satellite,FTA&Scrambled,custom)
                            5:All channel & Favorite's channel edit & move
                            6:Add favorite's program to OK list
                            7:Add multi audio track switch
                            8:Fix T & T2 channel switch no signal
                            9:Add backup & restore
                            10:Source code optimization
                            11:Uses the remote controller to enter the English name for favorite
                            12:Other
