VERNEE MIX 2 4G PHABLET 6GB RAM / 64GB ROM BLACK FLASH DEAL ON GEARBEST
    If you in need of a Stylish Smartphone with good Specs you should take a View on the VERNEE MIX 2 PHABLET.
    The Phone comes with 6GB of Ram and 64GB Rom it has 6 inches superlarge almost Bezel-less screen,
    which you will hardly see in any other budget bezel-less smartphone.
    Quick Specs:
    Design Ultra narrow bezel
    Display FHD+
    Screen Size 6.0 inch
    Camera Triple Cameras (13MP+5MP Rear & 8MP front)
    Hardware MTK6757CD Octa Core 2.5GHz
    Software Android 7.0
    Battery 4200 Non-Revovable Type
    RAM+ROM 4GB+64GB (Memory Card support up to 128 GB!)
    Network Support 2G/3G/4G
    OTG Support Y
    Sim Card Type Dual sim
    Vernee Mix 2 has the 13 MP dual rear camera, It is the first model from the VERNEE featuring the dual rear camera set-up. With this facility, you can blur your background in the photo within the phone camera itself!
    It is equipped with the 4GB RAM and 64GB ROM, It has the latest Helio P25 chipset with 2.5GHz, Octa-Core processor, which makes this phone very smooth while operating. With is 18:9 all screen will bring a more broad vision when playing high-quality games.
    You can buy VERNEE MIX 2 Smartphone from Gearbest.
    A flash sale is in progress on this site for this product, so go and grab your Mix!
