(Fully optimized for speed)
-- Latest Version --
CSA91 - Krypton V4-FULL Firmware DOWNLOAD
Rom based on Zidoo official version 1.0.45
See Change log on Zidoo site
Full Featured fully functional Functional.
Latest Kernel
Optimized Ram.
Latest Security Patched.
All Applications Updated.
Pre-Rooted.
Pre-Activated.
Work for any R68/R8 or equivalent Devices with:
Realtek RTL8723BS - WLAN 802.11bgn, Bluetooth 4.0LE, FM combo module.
Realtek RTL8211E - 10Base-T / 100Base-TX / 1000Base-T LAN Compatible Devices.
1G/8G Also Compatible.
Hardware Clock Working.
FOR OTHER DEVICES (RK3368 only):
STEP 1 - Flash your device Resource.img after flashing the above firmware. Test if it works i.e wifi, Bluetooth etc if not go to STEP 2
STEP-2 - Flash both Kernel.img and Resource.img after flashing the latest above firmware and test.
(No guarantees on working of firmware on other devices)
Zidoo has not updated its ZDMC version to 17.xx on ZIDOO X6 PRO. Let me know the stable Kodi or other build so that I can update in firmware.
You can also install official Kodi build to test how it works.
-- Previous Versions --
CSA91 - Krypton V3-FULL Firmware DOWNLOAD
Rom based on version 1.0.39
See Change log on Zidoo site.
CSA91 - Krypton V3-LITE Firmware DOWNLOAD
CSA91 - Krypton V2 Firmware DOWNLOAD
Rom based on version 1.0.38
Minor Bugs Fixed.
Optimize Zidoo Launcher to Speedup.
Supersu Binaries Updated to Latest.
Zidoo Updater Removed
CSA91 - Krypton V1 Firmware (REMOVED)
Flash with Android Tools 2.35 DOWNLOAD
Please Note: After Flashing and booting for 1st time only **Wait for few minutes on the Language Select Screen** before jumping in. Let the Firmware complete the installation of all applications
Further Optimization Tip
Zidoo Firmware by DEFAULT "Windows animation scale, Transition animation scale and Animator duration Scale are set to 1x
which is kind of slow. For best experience set them all to 0.5x From Developer Option you will feel the difference.
- KrYPton
