Minix X7 Hybrid Firmware (HFW) 1.2.1 by lewy20041
    This firmware is based on the latest relised by minix.
    You can find some nice GTV apps here:
    My website:
    http://www.apkfreak.com
    Changelog:
    v2.0.3
    -cwm recovery (backup-restore your firmware)
    -Xbox360 wirless gamepad butons remaped to support more games
    -swich between 1080p kernel and 720p kernel with simple press of a button from your tv
    v2.0.2
    -all futures of 1.2.2
    -fixed remote mappings
    -new base firmware
    -new option Settings>Hybrid>TV Optimised Apps (points to my weebsite download section
    with google tv apps, tv frandly apps, and some other useful apps)
    -new option Settings>Hybrid>Download XBMC (point to latest nightles with HW accel)
    -new options under Settings>Hybrid>Advanced
    *reboot
    *reboot recovery
    *reboot bootloader (it will get you to flash mode)
    *swich resolution (i will provide this firmware with 1080p kernel, if you click swich
    resolution it will swich to 720p, so you can wach movies in 1080p and lets say play
    games in 720p if you want better performance)
    -pached libmedia for xbmc passtrougt (need test)
    -spdif k-r42/minix x7 passtrought should work out of the box (need test)
    -latest wasser karnel k-r42 (thanks for your help)
    -some build.prop changes
    -new folders in /mnt/ out of the box fro mounting nfs or smb shares
    NFS_1 ; Samba_1
    NFS_2 ; Samba_2
    -mount smb, nfs scripts in /etc/init.d/ for mounting shares (edit to mach your shares and
    change permisions to "755" "rwx r-x r-x")
    -alot of things i dont remember;p
    v1.2.1
    -firmware migration (!there might be some bugs due to hevy changes, please post your findings!)
    -new shutdown menu
    -power off working as it should
    -new base firmware (latest minix firmware)
    -fixed setting/firmwork-res strings
    -screenshot button can be turned off/on in settings (!change location of screenshot to sdcard!)
    -autohide statusbar option in settings>display
    -new 720p kernel to prevent reboots (from "ugoos ut1") !this is just for K-R42 ver!
    -new modules
    *md4.ko
    *pl2303.ko
    *crc-itu-t.ko
    *isofs.ko
    *cdrom.ko
    *udf.ko
    *isofs.ko
    -"special" removed from HFW Settings, "Dev Settings" added insted
    -alot fixes, tweaks etc.
    v1.2.0
    -DTS pach
    -fixed glow on gamepad button
    -youtube for gtv ver downgraded to 1.6 (due to login problems on 1.7.1)
    -better webcam support (logitech webcams like c525 wasnt working before, now it works like a charm)
    -bootsound suport (put any .mp3 into system/media and rename it to android_audio.mp3 it will be played at bootanimation screen.)
    -auto install advancedsettings.xml for smooth 1080p videa playback in XBMC
    -back to stock with apps icons
    -nfs support
    mount your share using terminal with this command (edit to mach your share) or edit 05NFS script in init.d folder:
    Code:
    su
     mkdir /sdcard/nfs
     busybox mount -o rw,intr,soft,nolock 192.168.1.102:/mnt/HD/HD_a2 /sdcard/nfs
    v1.1.2
    -other bug fixes
    -added HFW version under settings>about device
    -new modules:
    *ntfs.ko added
    -some visual changes
    -modules package [provided with the rom package]
    (if you want tu use any of additional module, just extract the "Modules RK3188" package
    chouse module you want to be loaded at startup, rename it to "custom.ko" and put it in the root of internall sdcard
    it will auto load on start (be sure that you rebooted device at least 2 times).
    you can put up to 3 custom.ko (custom.ko; custom1.ko; custom2.ko)
    -disabled hdmi check for apps like "Xfinity, HBO GO" (test)
    v1.1.1
    -fixed random reboots on MK908
    -Default launcher option under HFW settings>USB (Chouse which launcher you want to use as default)
    v1.1.0
    -spoofed as Galaxy SIII
    -button on statusbar opens "Tincore Key Mapper"
    (you can play games like bad pieggies with mouse)
    -new visual (icons, system bar etc.)
    -power button on system bar
    -new settings (HFW Settings)
    *Performance (you can change CPU clocks)
    *Equalizer (need some testing)
    *SuperSU (now it wil show here insted of app drawer)
    *Terminal (//-//-//-)
    *Xbmc Installer (//-//-//-)
    -btusb.ko insmoded at startup (no bt dongle support yet)
    -tun.ko insmoded at startup (thanks go to leolas from freaktab.com for compile this modules for me)
    -clean home screen from usles shourtcats and widgets
    -some other things i dont remember;p
    v1.0.0
    -root
    -build.prop tweaks
    -spoofed as GT-I9100
    -gameloft fix
    -2gb app space
    -changed bootanimation
    -virtual touchscreen.ko insmoded at boot
    -deleted usles apps
    -added some nice apps:
    *ES Explorer (ver. before layaut change)
    *Wallbase
    *Youtube for GTV 1.7.1
    *SuperSU
    *TV Launcher 3D
    *XBMC Installer
    -unlocked hiden options:
    *Bluetooth
    *Accessibility
    -init.d support
    -new wallpaper
    -ic_sysbar_highlight changed to cyan
    -ic_sysbar_lights_out_dot changed to transparent (no dots on status bar when waching movie on mx player etc.)
    -added gamepad button on statusbar (no functioning yet)
    -deleted search bar from home
    Download:
    v2.0.3
    First tv box/stick firmware to switch between resolutions!
    Download 720p/1080
    v2.0.2
    Download 1080p
    Regards
    Lewy20041
    Thanks go to:
    leolas (for his help whenever i need)
    phjanderson (kernels for t428)
    hoabycsr (kernels for mk908)
    Everything is possible if we work together!
    ApkFreak
    Congrats Lewy!
    You getting faster than me
    I stuck this thread for you since your ROMs work well for people.
    I am working on my own X7 ROM now.
      i found a problem with webcam so the rom is delayed for tomorow;p
      edit:
      thx Bob.
      im haveing fun makeing roms
      so no big deal
      ApkFreak
        Nice!
        Looks very nice Lewy. I'm in the process of making a review of the X7 now. Its already awesome but this looks even better. I have the Logitech C525 webcam so that would be awesome to have it working. Anyway I would like to link users to this ROM will it be as easy to install as Bob's ROMs or the stock ROM?
        Thanks,
        Rivers from SomeCoolTech
          as the stock
          i found the webcam problem and its in the kernel of my device.
          so no need to delay the relise for minix x7.
          i to have c525, i checked if it work with minix kernel and its working 100%
          link in first post
          ApkFreak
            Sv: Minix X7 Hybrid Firmware (HFW) 1.2.1 by lewy20041
            Thanks for your development. I am going to use it when I receive my x7 )
            Also i am glad to hear from Finless about his development.
              XBMC advancedsettings.xml
              I can't seem to find the advancedsettings.xml on the system after installing HFH XBMC Installer. I did a busybox find / -name advancedsettings.xml and nothing was returned. Am I doing something wrong? What settings need to go in this file? I also want to add my mySQL XBMC information in this file. I can copy my version but it obviously doesn't have the settings to resolve XBMC 1080p playback.
              Also, once you HFH Settings\XBMC Installer, if you try to run it again you will get 'Unfortunately, Settings has stopped" and the settings window will be closed. I understand you should only run this once but I figured I should point out this error.
              Regards,
              -Darren
                Since you are using the UT1 kernel...if I flash this ROM to my UT1, I shouldn't have to change the kernel first..... Is that correct?
                I'm downloading your ROM right now, but it might be a couple of days before I can try it.
                Thanks for the ROM. You put a lot of work into this one!!!!!!!!
                I put together a ROM for the UT1...but I'm having trouble getting NAND to format/mount. Hopefully yours will work to fix that.
                Randy
                  BlueTooth Share has stopped
                  Once the system boots I get two of these "Unfortunately, BlueTooth Share has stopped". Also, I can no longer link my PS3 Controller with Sixaxis because BT is not functioning.
                    Re: Minix X7 Hybrid Firmware (HFW) 1.2.1 by lewy20041
                    Thanks !! I think I am gonna wait for a bugless firmware. Loving my x7
                    Best regards
                    Verstuurd van mijn HTC One met Tapatalk
                      Works nicely on my T428 with phjanderson's vsync-fixed and oc'd 1080p kernel. Video performance is on par with the latest nexus ROM.
                      A few little quirks: I'm also seeing these "Unfortunately, BlueTooth Share has stopped" messages after every reboot. Also selecting Settings->Sound->Volumes shows "Unfortunately, Settings has stopped" and exits to the home screen.
                      NVidia Shield TV 2015 16 GB || Stock
                      NVidia Shield TV 2017 16 GB || Stock
                      Buy me a beer?
                        for that bluetooth problem.
                        delete /system/app/bluetooth.plus.apk
                        and post back if bluetooth is working without it.
                        rom link puled down for now.
                        im fixing it now.
                        ApkFreak
                          Regards,
                          -Darren
                          advancedsettings.xml will show on third boot i think.
                          its scripted that way:"
                          as to Settings->Sound->Volumes
                          im avere of this, i will fix it but its usless anyway:"
                          rrileypm, i think you can use k-r42 firmware without any modification needed:"
                          ApkFreak
                            ok. fixed.
                            link in first post.
                            feedback please
                            ApkFreak
                              T248 v1.2.1
                              Hi Lewy,
                              Is this the same as you posted under T428 thread ( v1.2.1) I mean same features?
