What size barrel plug is used in this box?
Hi ,
you need for sure a 5V/3000mah Powersupply , how it looks and size are not
so important , only the same , Connector to Box , is important .
good luck / gefattern
Hello Merk, I have been trying to solve the same issue, basically I was going to use a battery pack and power the device without electricity, the common barrel connector is 5.5 2.1 connector , however your device is simply a smaller one, try 1.35mm barrel connector, i'm using a external battery pack to power my android box lasts for a long time, you will need a USB to barrel connector in order to supply power from battery pack to android box. The crazy part none of the sites actually tell you barrel sizes for your power.
Hope it helps!! happy christmasLast edited by opticspy911; 02 December 2017, 19:39.
Here is an update to barrel size of Android Box , the M8 Pro or S912 android boxes, 2.1mm is too large, and 1.35mm is too small, I found the 1.7mm barrel connector must be the correct size.... I have already ordered it on amazon, basically trying to battery power my android box for outdoors use, I will confirm this one works...
Originally posted by opticspy911 View PostHere is an update to barrel size of Android Box , the M8 Pro or S912 android boxes, 2.1mm is too large, and 1.35mm is too small, I found the 1.7mm barrel connector must be the correct size.... I have already ordered it on amazon, basically trying to battery power my android box for outdoors use, I will confirm this one works...
There are currently 3458 users online. 0 members and 3458 guests.
