[Firware Stock] VORKE Z6 ANDROID 7.1.2 AMLOGIC S912 TV BOX FIRMWARE
    As Found:
    Plus Model 3/32
    06/06/2018
    http://geekbuying.mediafire.com/file...80606.img/file
    Source:blog.geekbuying
    08/03/2018
    PC Flash Firmware
    www.mediafire.com/file/2qq6nscj5253epx/VORKE-Z6-20180126-PC.zip
    SD Flash Firmware
    www.mediafire.com/file/7wd01anr97qv2r3/VORKE-Z6-20180126-SD.zip
    Source: Blog.geekbuying
    Glad to share the firmware for VORKE Z6 TV Box
    PC Flash Firmware
    Flash guide, please refer to: http://blog.geekbuying.com/index.php...utorials-tool/
    Source blog.geekbuing
    Originally posted by trebor View Post
    As Found:
    PC Flash Firmware
    This unrooted firmware.
    Is there a way to root this box?
      The reset button's hole is way too small.
      I opened it up to make it easier.
      I have no idea what Tanix/Vorke was thinking.
      Their hole does not even fit a toothpick.
        What's new in this version?
          Nothing. Forget it. It's the unrooted version.
            I have ordered it from Geekbuying one week ago and still didn't receive an email confirming it is shipped, did anybody have same problem?
            BTW, do I need to use a blower an any cooling fan?
              I got a confirmation it was sent after a week of ordering. It got here 3 weeks after ordering.
              It takes a while.
              The box does get hot. Making the vent holes larger and having a fan will help a lot.
                install Magisk
                Hello, welcome to the beta Magisk thread! First check the main thread before starting. I expect users reporting to at least have basic debug skills, this thread is heavily moderated so refrain from spamming with "useless" reports! Latest Magisk...
                  i send an e-mail to vorke support with this question waiting for answer
                    Don't flash the box with the new firmware would be the easiest fix. lol
                      I know, but it was in the unlikely event that someone would report any positive changes after flashing the firmware.
                        Update firmware Zorke Z6 Freaktab << Click
                          hello.is the SD firmware the rooted one?I'm trying to find the latest SD unrooted version months now without luck...
                            Update Zorke Z6 PLUS 3/32 20180606 Freaktab << Click
                              Update Zorke Z6 20180606 Freaktab << Click
                              firmware update for Vorke Z6 Plus
