13:54:57 T:1741109032 NOTICE: [StorageServer-2.5.2] '_sock_init' : ''
13:54:57 T:1742979160 INFO: CPythonInvoker(0, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py): script successfully run
13:54:57 T:1742979160 INFO: Python script stopped
13:54:57 T:1741109032 NOTICE: [StorageServer-2.5.2] '_sock_init' : 'Done: u'/mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/temp/commoncache.socket''
13:54:58 T:1741109032 NOTICE: [StorageServer-2.5.2] '_startDB' : 'sql3 - /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/temp/commoncache.db'
13:54:58 T:1741109032 NOTICE: [StorageServer-2.5.2] 'run' : 'Exception: error(1, 'Operation not permitted')'
13:54:58 T:1741109032 DEBUG: LocalizeStrings: no strings.po file exist at /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/resources/language/English, fallback to strings.xml
13:54:58 T:1741109032 NOTICE: [StorageServer-2.5.2] '_showMessage' : '<type 'unicode'> - <type 'unicode'>'
13:54:58 T:1741109032 INFO: CPythonInvoker(2, /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): script successfully run
13:54:58 T:1741109032 INFO: Python script stopped
