From the Ugoos blog...
"All AM3 devices will get Android 7.1.2 Nougat update automatically via OTA
Good news for Ugoos AM3 users!
Nougat AM3 Testing process is finally finished.
First of all, we want to say THANK YOU to all our users who had spent their time to install BETA version manually and sent reports to us and discussed appeared problems on forums. You help us a lot!"
"Update will come automatically, if you have any problems with OTA you can use manual OTA pack or reflash your device using a full image:
Ugoos AM3 Nougat V2.0.0 Full Image
Ugoos AM3 Nougat V2.0.0 OTA Update Pack
Ugoos AM3 V 2.0.0 Changelog 11/17/2017
1. Added stop playback setting when disconnecting HDMI (Playback settings)
2. Fixed keyboard notification
3. Fixed cursor bug when playing in full screen mode
4. New USB mode settings
5. Improved Debug Settings
6. Improved NFS client
7. Improved Samba Server
8. Fixed Xposed support
9. Removed Quick Search Bar on first screen in Launcher3
10. Fixed "Disable USB audio routing" option. Added this to sound settings
11. Added Ugoos Launcher
12. Added CIFS Client setting
13. Fixed afr frequent rewind
14. Fixed Settings app crash when bluetooth pairing
15. Fixed bootloop if changed access of build.prop
16. Fixed LED sleep
17. Fixed TeamViewer remote control support
18. Playback fixes
19. Changed Screen position settings"
