T95R PRO 3GB/16GB
    T95R PRO 3GB/16GB
    hI,
    does anyone have a firmware image for this box please?
    I have bricked it and can only access it by usb! Any help would be much appreciated,
    Thanks in advance
    jumpy
    Any one able to help with this please?
      Android 7.1 stock firmware for T95R Pro TV Box https://chinagadgetsreviews.com/down...ro-tv-box.html
        Thank you blinkone, can I just use the image from this as by box will only recognise the usb burning tool?
          Yes you can, Iv not tested the firmware though as I do not own that device.
          Good luck
            Grrrr no go! It gets to 7%formatting and stops with this error
            UBOOT/Disk initialize/Send command/Timeout
            Any idea's please?
              Confusing
              Looking on the sticker on the bottom of the box it says 2gb/16gb!
                Hi jumpy, Run USB Burning Tool click on view at the top left and select temperature setting.
                Untick range and all should be good.
                As long as you have correct firmware.
                Cheers
                Kevin
                  Cheers
                  Kevin
                  Thanks Kevin, but i'm afraid that option is already unticked!
                  Have tried several different versions of the burning tool without success.
                    Any more idea's please guys?
                    How do you post pics of the board that are only 2mb?
                      This link actually is for Android 6 not 7
                        Are there another link . Because the link is not right version and when I setup it the wifi doesn't work again .
                          @qusay,
                          Is there anything here u can use?
                            Boneo
                            thank you ...
