Many thks to gearbest for sending me the device to play
Must of the changes where under the hood
I REALLY RECOMMEND ADDING A HEATSINK TO THE CPU!!!
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
THIS ROM CAN ALSO BE USED ON NON-VTV Versions.
Changelog V1:
- 55% based on stock
- Big optimization, is really fast now and i mean fast... you will see it!
- Navigation should be smooth as silk and fast.
- New Boot Logo, many thks to danielelek90 for the great work
- Fixed passthrough in Kodi 17, SPMC 17, FTMC 17, maybe others... (DTS, DTS-HD etc...)
- Double press home button brings the app switch(app kill) use the del button on VTV remote to close open apps.
- Fixed supersu binary update bootloop
- Fixed UI crashes
- Some UI changes:
- - organized the icons on status bar dropdown.
- - fixed and screenshot function on navigation bar
- - removed led control from navigation bar
- - Fixed and added back power button in navigation bar
- Some video optimizations ( tested in two different's online ISP's TV and both give HD streams just fine )
- Fixed Some launchers not working (Nova Launcher...)
- Enabled Multiusers ( Max 2 )
- Enabled round icons, if the apps supports it.
- Custom Wetek WebOs launcher (Many thks to wetek for let me use it)
- - Menu Button is king on this launcher, its used to add remove icons on the main screen, also to remove widgets.
- - Long press on the default icons on desktop you can change them to other apps (White Logos...)
- - Long press on the icons you add to the deskop and you can rearrange them.
- - Bing Pic of the day background.
- Netflix, youtube, playstore...etc... fully working
- 4k Youtube support.
- initd.d support.
- PS3/PS4 gamepad support ( only with cable... )
- Added Xbox360/XboxOne gamepad support ( cable, wireless and Bluetooth )
- Added Dragonrise USB HID game controllers.
- Fixed gamepads keys
- Added upper and lower bars ( status bar and navigation bar )
- Added Status and Navigation's bar's auto hide!
- Wifi range and connection speed should be a little better.
- Permissions fixed. ( lots... )
- Many KL's added.
- Fixed AMCODEC playback.
- Some audio mods.
- FTMC Build 31
- Added Android TV screensaver ( default 1h timeout )
- Added a setupwizard.
- Optimized some animation stuff!
- Removed the hard locked launcher, so you guys can now choose your own launcher.
- Added lighthome launcher, so now theirs 2 on the rom.
- And a lot of other stuff that i dont remember now! ( ye ye i know i need to make notes... )
- In youtube app when you search if it ask to access you microphone deny it or else it will crash.
- No TWRP for now, im having some weird issues with it... so that is going to take more time... sorry no Magisk install of course because of that
- The DTV app Icon is to dark on WebOS, they need to make a new DTV icon...
- Possible a lot more!
Want to buy me a beer?
Download SCV1 IMG:
- DOWNLOAD HERE SCV1 VTV for Khadas Vim 2
- MD5: FC040C810927CE56DC6A4FE86048C3FD
Install instructions:
- Use usb burning tool.... the img
- Use recovery the OTA..
Where to buy:
1ยบ BOOT MAY TAKE +/- 6 MINUTES!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
