The author/reviewer must have done a lot of research.
Basic hardware | Model: H 96 Pro + CPU - model: Amlogic S912 CPU - Type: ARM Cortex-A53, 1,5GHz, 64b Number of cores: 8 GPU ARM Mali-T820MP3 RAM - Size: 2 GB / 3 gigabytes of RAM - type: DDR (based on specific assembly) ROM memory - size: 16 GB / 32 GB / 64 GB ROM memory - type: eMMC v 5.0 Maximum supported external storage: 2 TB Wi-Fi: Yes, 2.4 / 5 GHz, IEEE 802.11a / b / g / n / ac standards Bluetooth: Yes, Bluetooth 4.1 + HS Wi-Fi / BT Chip: Yes, type by specific assembly LAN: Yes, 10/100/1000 Mbps |
Graphics and video output | GPU: ARM Mali-T820MP3, up to 750 MHz (DVFS) HDMI: 2.0 / 2.0a (based on a specific assembly) HDMI CEC: Yes HDR: Yes HDCP: 2.2 |
Video Codecs | VP -10 H.264 H.264 AVC HP L5.1 up to 4Kx2K 30fps H.264 MVC up to 1080P 60fps MPEG-4 ASP L5 up to 1080P 60fps (ISO-14496) WMV / VC-1 SP / MP / AP up to 1080P 60fps AVS-P16 (AVS +) / AVS-P2 JiZhun Profile to 1080P 60fps MPEG-2 MP / HL up to 1080P 60fps -13818) MPEG-1 MP / HL up to 1080P 60fps (ISO-11172) RealVideo 8/9/10 to 1080P 60fps WebM up to VGA |
Supported formats | Decoders: H.265 / HEVC, HD AVC / VC-1, HD MPEG 1/2/4, RM / RMVB, Xvid / DivX 3/4/5/6, RealVideo 8/9/10 Video ASF, DAT, FLV, ISO, MKV, MOV, MPEG, MPG, RM, RMVB, TS, VOB, WMV Audio: AAC, AC3, MP3, OGG, WAV, WMA Photo: HD JPEG, BMP, GIF, PNG, TIFF |
Audio | HD Audio via HDMI: yes Dolby Audio: yes DTS Audio: yes 5.1 Surround sound: Yes Digital audio via S / PDIF: yes |
System | Operating system: Android Version: 6.x Marshmallow / 7.x Nougat (based on specific assembly) Supported Languages: 24 Supported Internet Services: Netflix, YouTube, Facebook, Flicker, Picasa, Skype, Gtalk and more Support DLNA, Miracast and Airplay: Yes Google Play Support: Yes |
Power supply | Common electrical network (local standard) A matching power supply / adapter is also included in the scope of delivery Type: External power adapter + jack (5 V / 2 A) |
Size and weight | Dimensions (L x W x H): 10,70 × 10,70 × 2,00 cm Weight: 0.2500 kg Packaging dimensions (L x W x H): 16.00 × 15.80 × 8.00 cm Package weight: 0.4700 kg |
Package contents | 1 x H 96 Pro + TV box, 1 x remote control, 1 x HDMI cable, 1 x AC adapter, 1 x user manual (English) |
There are currently 1312 users online. 1 members and 1311 guests.
