I Paired my BT Bluedio headphones and did a bit of not to be seen Jiving around All good while YTing and using Bluedio Headphones.
Google startup also good, installed apps all went well
Have Root, No SU, Upper and Lower Notification and Task bar.
Nothing to savage in the temp area while testing idle around 50c up to 65c +/- about 28c here at the moment. Ok lets see what we have...
UI/Desktop, installed apps,
Blueido Headset BT easy connect, Blue Glow of the Vorke and just see clock glow too bright I think.
Not too shabby for a S905W, BT and Dual Wifi wifi may help with better streaming and Input/output devices, long as is does not slow things down or put extra load on the CPU.
Thanks To Geekbuying,
I am sure there will be some more coupons soon.
More can be seen > http://freaktab.com/forum/tv-player-...ac-wifi-bt-lan
And Discussion...
