Just bought a Q-box 16gb,android 6.01
I am having issues with the Google Play Store.There are 2 play store apps installed.The shortcut on the home screen launches version 1.0.If I launch this and log in to my account it closes after 30 seconds.
The other is version 8.4.19 which I can only launch by going to settings - apps - play store.This one appears to work but it sits there checking for updates FOREVER .
So,I just installed Ugoos tv launcher,the home screen now shows icons for both play stores.When I try to delete version 1.0 it asks if I want to unistall.That always fails and the icon remains.
I believe my box is rooted.
What should I do ? Uninstal versin 1.0 ? If so,how ?
All sorted now,removed 1.0 with ES File explorer
