GS1_102N0 (2G+16G)
    GS1_102N0 (2G+16G)
    Hi dear , here comes the firmware for GS1_102N0 !
    Current version : GS1_102N0 2G+16G
    Based on : GS1_101N0 2G+16G
    Improvements :
    1. We solved the problem that some updates zips have been used wrong ;
    2. The problem that the enable startup wizard option has no reponse in setting when you click it has been solved ;
    3. Now the HD over 2TB can be available for you really ;
    4. The TF card can be a way to update your device ;
    5. The music player won't be seen in video files ;
    6. You can get a better user experience when you watch a movie ;
    7. Now the back button can be used freely when you open the kodi ;
    8. Wifi problems get improvements now .
    USB zip :(update_GS1_102N0.img):
    https://beelink-my.sharepoint.com/personal/firmwareservice_beelink_onmicrosoft_com/_layouts/15/guestaccess.aspx?docid=18ce4784844814aeaafdace1237 38a1a8&authkey=AYSNt52FFsFiPgpg5h52Q8E&e=296caebce 1f047fe8708b19e3ea185b6
    SD card zip : (ota_GS1_102N0.zip):
    https://beelink-my.sharepoint.com/pe...98fdfb9887c44d
    usb burning tool :
    https://beelink-my.sharepoint.com/personal/firmwareservice_beelink_onmicrosoft_com/_layouts/15/guestaccess.aspx?docid=12dc4c7891e8644a0bee6b900dd 3d0b97&authkey=AccwbdLr_86eEGEEucoSJv8&e=916044d23 0f6469689be6c709dbf403d
    USB updating :
    1. Install the allwinner USB burning tool first ;
    2. Click the PhoenixUSBPro.exe in your desktop and run it ;
    3. Click the upper left button to load the firmware file from your pc ;
    4. Click the lunch button on this interface ;
    5. Hold the reset hole and then connect with the computer and tv box , you should keep in mind that the USB2.0 is used for updating but USB3.0 . after that , it is a recognization sign that the red X ( upper right corner)turns green .
    6. Finish this updating .
    SD card updating :
    1. copy this file (ota_GS1_101N0.zip) to your TF card or U-disk and then insert the TV box ;
    2. go in the setting > click the option of "about the media" > choose the first option > choose file > load the ota_GS1_101N0.zip ;
    3. the systen will recognize this update zip automatically when you run it well and then shut down to go in the update mode , you need to make sure that Power
    supply must be firmly good enough to finish this updating , power outages would contribute to a failure .
    you can contact with me if you meet some problems .
    email : [email protected] / skype : +86 18772960513
    Improvements :
    usb burning tool :
    USB updating :
    SD card updating :
    Thanks!
