Yet an nother Freaktab Giveaway!
This Time we have an Smartphone for you, not just an Smartphone.
It is the VERNEE MIX2 6" Smartphone.
To start of with, this phablet is offered in two neutral colors that are suitable for most people, Black and Blue.
Size of the device is 15.78 x 5.77 x 0.82 cm and has an weight of 0.2050 KG.
It´s screen is large being 6.0 inches in size, with rounded corners and an extra narrow frame.
For the Screen Ratio of 18:9, it is much large than most other smartphones, where the ratio is 16:9.
The Screen also delivers 2160 x 1080 resolution, which makes it fully high definition.
This Phablet also feels great to the touch, with the metal frame and glass on the front and back.
Under the Hood we have the MTK6757CD Octa Core processor with 2.5 GHz frequency provides with a fast and smooth experience.
Quick Specs:
Vernee Mix 2 4G Phablet 6.0 inch Android 7.0 MTK6757CD Octa Core 2.5GHz 4GB RAM 64GB ROM 13.0MP + 5.0MP Dual Rear Cameras Fingerprint Scanner
● Display: 6.0 inch, 2160 x 1080 Pixel screen
● CPU: MTK6757CD Octa Core 2.5GHz
● System: Android 7.0
● RAM + ROM: 4GB RAM + 64GB ROM
● Camera: 8.0MP front camera + 13.0MP + 5.0MP back cameras
● Sensor: Ambient Light Sensor, E-Compass, Gravity Sensor, Gyroscope, Proximity Sensor
● SIM Card: dual SIM dual standby. 1 Nano SIM card + 1 Nano SIM card
● Feature: GPS
● Bluetooth: 4.0
● Network:
2G: GSM 850/900/1800/1900MHz
3G: WCDMA 900/2100MHz
4G: FDD-LTE 800/900/1800/2100/2600MHz
What i have to do to Win?
Take a look at the Gearbest Black Friday Promotion and leave your wish lists product link here.
We will choose the lucky one to send out VERNEE MIX2!
For the Color, you can have Black or Blue :-)
Here is the Black Friday Promotion of Gearbest:
Black Friday Main Event Nov.23 @17:00 Nov.27 @17:00
Cyber Monday Promotion Nov.27 @17:00 Dec.4 @10:00
10% OFF Sitewide Coupon GBNovember
Rules:
- This Giveaway will run until 2017-12-04
- The giveaway is an international giveaway
- You must be the age of majority in your Country of residence.
- Only one entry per person
- This giveaway is operated by Freaktab.com / GEARBEST
Now take your Chance to Win an enter that Giveaway........
The Giveaway is over now, and we have an Winner!
It is the User @mirelurk!
Gratualtion from Freaktab and Gearbest!
