Here is coming new firmware 706D0 version!
Current version: GT1_706D0_AP6255
Based version: None
Android Version: 7.1.2
Fits for : ultimate / 3G+32G A......D0.......(AP6255) ,for example : " A706D0SBH70001 32G " there is only one wifi chip for D0 , it's AP6255 .
USB burning tool :
https://beelink-my.sharepoint.co ... 4JInsGgzNYvz5qnW-9c (2.0.5)
https://beelink-my.sharepoint.co ... uaAYAcoK-dm4kmsvCs4 (2.0.9)
USB zip :
Updating tutorial:
https://www.youtube.com/watch?v=m8chkgcfcwQ (USB)
Improvement:
you can have a try to write it down and keep other babies informed of it when you finish this process .
Pay attention to :
1. A912/AX12-----AP6255 G912/S912-----QCA9377 A706D0SBH70001 32G---------D0 AP6255
2. You need to use the firmware which starts from the 70X D0 since a new barcode has been use to the GT1 , i will post it in the next thread . just like this series number shows :
" GT1 3G+32G D0 version : A706D0SBH70001 32G "
You may cause the blue screen / pink screen problems if you get something wrong , so you can as me for help if meet some problems about it .
3.Some links before the 707 NO have been deleted to avoid the updating errors , you can turn me for help if it's necessary .
4.You can only update the firmware from system 6.0 (301MO/101MO.......) to system 7.0 (701NO......)by USB updating , on the other hand , you can update the firmware from system 6.0 (301MO......)to system 6.0 (312MO,313MO) by SD card or USB updating .
5.Standard edition (2G+16G/2G+32G) : before ( system 6.0 ) <101 MO ( system 6.0 ) < ......113 MO ( system 6.0 ) < ...... updating (system 6.0)
Ultimate edition ( 3G+32G ) :
before ( system 6.0 ) <301MO ( system6.0 ) < ......313MO ( system6.0 ) < ...... updating (system 6.0)
Standard edition / ultimate edition :
701 NO ( system 7.1 ) < 702 NO ( system 7.1 ) < ...... updating (system 7.1 )
If you have any problem, please contact with me at any time:
[email protected]
skype : +86 18772960513 (chanchanwang)
