Can't start my Cube T9 anymore (error during flash)
    Seems I have the same issue than LucaF:
    I've downloaded the stock Rom 1.08 Full (without Chinese app)
    Then with SPFT (v 5.1516.00), I flahed it.
    Based on previous message I may be wrongly selected Firmware Upgrade (but not sure)
    After the flash SPFT showed the pop up saying that it was done. Butnow I can't start my T9 anymore. I can press all buttons start/stop vol +/- nothing happen.
    Any support is welcome.
    Fab
    I did some other unsuccessful trials.
    In particular, I added in Rom 8 (without Chinese app) the file "MT6752_Android_scatter_6GB.txt". Then I tried to flash with "Format All + Download" :
    But after 20 [s], always have the same error message :
      Last update:
      I followed carefully this tuto (http://freaktab.com/forum/mtk-based-...s-etc/page15):
      But same result with the error message during flash.
      And the other bad news is that I also tested:
      I don't see the battery image when I charge it. I pressed power button more than 10s, but it doesn't change.
        Hi ,
        can you reach the Recovery ??? ( Power + Vol- ) , i always flash my T7 in "Download only" Mode ,
        greetings / gefattern
          Thank you for your interest Gefattern.
          Unfortunately: no.
          Nothing happen when I press the buttons.
          Fab
            Any proposal?
            I also repeated my trials with another PC. But same result (only difference, during flash, the error message arrive after ~40 s instead 20)
            Reading again the 26 pages of the thread "Cube T9 Rom/Tools/Mods. etc" it seems that I forgot at least one step regarding some drivers
            Could it be the cause?
            Fab
              Originally posted by Fab117 View Post
              Any proposal?
              Fab
              Hi ,
              if not all Drivers are installed , a Flash does not work , i think ??? ,
              please try to install this missing Drivers and try again , please
              report what happens .
              greetings / gefatttern
                There are 2 series of T9 Cube Tablets that differ for the preloader. Your case seems to be related to this problem
                Try this by replacing it with the one contained in the stock rom 1.0.8 (or 1.0.7)
                  Don't know why, but can't submit my message.
                  Will try to remove the url's
                  • trebor
                    trebor commented
                    Editing a comment
                    Spam Protection can go a bit overprotecting sometimes,
                  Don't understand why I can't post my message. Seems that the url links are the issue
                  I'll try to remove them
                  Dear Both,
                  Thank you for your help.
                  Unfortunately, not solved yet.
                  Below the details of what I did and the outcome.
                  1) I downloaded
                  i) Stock Rom 1.08 Full (Senza App Cinesi) Non ufficiale ma una mia release (.../#!RpRhRB6J!a6zlFQu5LQwfyMLkIQzRlycX-jURRqaMNkfkEwWFe4o).
                  ii) Nuovi files Scatter per /System 1,5Gb /Cahe 512Mb /Data 2,4,6,8,10,12,14,16,18 Gb (.../#!BhwxSR6D!EVSNog7r0NJUi7Fyv30WaAAaaRYvgSTHG7J_l4v Q18Y
                  iii) The preloader you reffered to (.../#!okhxGDAQ!Qb8QTjhNK...yJy8-OZ89991Xo)
                  iv) SP Flash Tool 5.1516.00 (.../#!gg5UjSwJ!OVh3aU_ik4PnAmMKtBG4Zm63Ci103T6vxx_LvZd snhQ)
                  2) I unzipped the 3 files
                  3) In T9_V1.08_20150326_NoChinaApp folder I added the file "MT6752_Android_scatter_15-512_6GB.txt" and replaced the file "preloader_htt8752_tb_kk.bin"
                  4) I launched "flash_tool.exe" as admin
                  5) In "Scatter-Loading", in the folder "T9_V1.08_20150326_NoChinaApp" I loaded "MT6752_Android_scatter_15-512_6GB.txt"
                  6i) I selected "Format All + Download"
                  click "Download" and then connected my tablet
                  After ~1mn, the flash was completed:
                  I then closed FPST and disconnected my tablet, but impossible to start
                  6ii) Same, but with "Firmware upgrade"
                  outcome:
                  But still impossible to start the tablet
                  __________________________________________________ _________________________________________
                  NB:
                    Is very strange but the process of installing the rom lasts too little. The tablet should be turned off when connected to the PC
                    SPFT use only Firmware Upgrade (Formatting deletes the imei of the tablet). At the end, you must unplug the tablet and restart it in recovery mode.
                    n recovery mode, perform a wipe with factory reset and restart tablet.
                      Dear Both,
                      1) I downloaded
                      outcome:
                      NB:
                      Hi ,
                      did you try to install the Drivers again ??? , maybe it helps to resolder the Battery new ,
                      disconnect and connect again , wrote it a long Time ago somewhere , not sure if it works .
                      good luck / gefattern
                        I'm not convinced that my tablet is off, because when I charge it, I don't see the battery image.
                        Could you please let me know how to proceed?
                          if your tablet is not turned off you can not see the installed drivers.
                          If your tablet is not turned off you can not enter in recovery.
                          Make sure your tablet is off, press the power button for 10 seconds.
                            I tested the 10 [s] (and even much more) press power button without success.
                            I also tested the flash on another computer with Windows 10.
                            I have been able to perform the flash (T9_V1.08_20150326_NoChinaApp + new uploader file + "MT6752_Android_scatter_15-512_6GB.txt") without installing any USB drivers.
                            But still the same: I can't start the tablet
                            Fab
