Current version :A1_706N0 based on :A1_705N0 android version :7.1.2 fits for:RK3328 DDR4/DDR3/LPDDR3 4G+16G/32G WIFI&BT: RTL8821CU(6221E) - 2.4G/5G Ethernet:1000M USB burning tool : https://beelink-my.sharepoint.com/personal/firmwareservice_beelink_onmicrosoft_com/_layouts/15/guestaccess.aspx?folderid=19a0ccf86d8054d959050982 9533ca035&authkey=AdclByimsc2ndc4yctaHVks&e=9b73d2 72bdfe4a7888f8626690ddb17d USB zip: https://beelink-my.sharepoint.com/pe...5743d069d4e849 SD zip: https://beelink-my.sharepoint.com/personal/firmwareservice_beelink_onmicrosoft_com/_layouts/15/guestaccess.aspx?docid=18afe1fed5ef24ce9996411ef3c 17b87c&authkey=AcopwD95U3RXnI6ecHFAJhY&e=8e17c1f2f 0a64f50ac3e359e09701b4e Improvements: 1. this device can support the exFAT style now ; 2. The Dolby&DTS audio effect has been improved ; 3. The meidacenter supports the smb&nfs now ; 4. The stability of skype has got better ; 5. the external storage devices are available for reading by the third-party apps ; some tips for updating : 1. USB updating : 1)Install the DriverAssitant_v4.5 first and double click the DriverInstall.exe , then you need to choose the "install the driver"option to finish this installation ; 2)Open the USB bunning tool which is named FactoryTool-v1.43e and then double click the FactoryTool.exe ,now it's time to click the "firmware"to load it well . 3)Click the "start" and hold the reset button still to connect the double USB cable , then you can take it easy to wait for the updating . 2.SD updating : 1.Format your sd card with the FAT32 fromating style . and then you need to copy the update.zip file to the root of the SD card ; 2)Insert the sd card to the port ; 3)Wait for the updating pop news and choose the update option . you need to make sure that Power supply must be firmly good enough to finish this updating , power outages would contribute to a failure . you can contact with me if you meet some problems . email : [email protected] / skype : +86 18772960513 |
A1 706NO 4G+16G / 32 G
There are currently 4362 users online. 0 members and 4362 guests.
