Vorke Z6 TWRP recovery???????
Newbie here..... Just got my Vorke Z6 box and I love it. All my apps work Netflix, Hulu, etc but my Direct TV Now won't work because it see's root. I was able to watch it on my Nexus Player by installing magisk and using the magisk hide app. I have download the Vorke Z6 TWRP version, renamed it to recovery, and placed it on my sd card. Rebooted using reset method but TWRP will not boot so that I can install magisk. Anyone have a solution to this? Any help would be greatly appreciated.
Tags: None
Try it godd lock
There are a few different ways to install Magisk. If you're already rooted and you just want access to Magisk modules, you can use Magisk Manager to install the Magisk framework. Or, if you want to pass SafetyNet on a rooted device, you can switch from SuperSU to Magisk SU. But the best way to do it is to start fresh by installing Magisk on a non-rooted phone using TWRP.
Yeah I was able to flash Magisk but the issue I had was trying to find a TWRP recovery that would boot on my device. None of the images I downloaded here would work. I finally downloaded a compatible rom for my device, installed it, and used the "dd" command to pull the recovery image by itself. Now I have a standalone img that I can boot from my sdcard using the reset method.
Has anyone got DirectTVNow or SlingTV to play clear on this device? Netflix, Hulu, Amazon Prime, etc all play clear but SlingTV and Direct TV Now's quality is horrible.
Originally posted by jmccartyYeah I was able to flash Magisk but the issue I had was trying to find a TWRP recovery that would boot on my device. None of the images I downloaded here would work. I finally downloaded a compatible rom for my device, installed it, and used the "dd" command to pull the recovery image by itself. Now I have a standalone img that I can boot from my sdcard using the reset method.
*or can u upload the twrp file with google drive please?Last edited by kos25k; 19 March 2018, 09:40.
Originally posted by jmccarty View PostYeah I was able to flash Magisk but the issue I had was trying to find a TWRP recovery that would boot on my device. None of the images I downloaded here would work. I finally downloaded a compatible rom for my device, installed it, and used the "dd" command to pull the recovery image by itself. Now I have a standalone img that I can boot from my sdcard using the reset method.
Originally posted by kos25k View Posthey dude.can u please tell me a way to install twrp?I am ready to order this box,but my assumption is to have proper twrp working so I can flash xposed framework.thank you.
DONT USE REBOOT USE POWEROFF
Originally posted by KaszasMbest solution is to build your your own zip with that tool and flash first over adb then flash zip
have fun
https://forum.xda-developers.com/and...t3786991/page1
There are currently 2096 users online. 0 members and 2096 guests.
