Hi dear , here comes the firmware for GS1_103N0 !
Current version : GS1_103N0
Based on : GS1_101N0/GS1_102N0
USB zip :(update_GS1_103N0.img):
www.bee-link.com
SD card zip : (ota_GS1_103N0.zip):
https://beelink-my.sharepoint.com/pe...96b7efba61d8f8
usb burning tool :
https://beelink-my.sharepoint.com/pe...be6c709dbf403d
USB updating :
1. Install the allwinner USB burning tool first ;
2. Click the PhoenixUSBPro.exe in your desktop and run it ;
3. Click the upper left button to load the firmware file from your pc ;4. Click the lunch button on this interface ;
5. Hold the reset hole and then connect with the computer and tv box , you should keep in mind that the USB2.0 is used for updating but USB3.0 . after that , it is a recognization sign that the red X ( upper right corner)turns green .
6. Finish this updating .
Improvement :
1. We solved the problem that the rigion area on UI gets a crash ;
2. The wifi bugs of allwinner have been removed ;
4. You can copy what you want in Bee Files Explorer quickly ;
5. The fisher joy app has been removed ;
PS :Now you can update from the GS1 101N0 to GS1 103N0 with SD card also .
SD card updating :
1. copy this file (ota_GS1_101N0.zip) to your TF card or U-disk and then insert the TV box ;
2. go in the setting > click the option of "about the media" > choose the first option > choose file > load the ota_GS1_101N0.zip ;
3. the systen will recognize this update zip automatically when you run it well and then shut down to go in the update mode , you need to make sure that Power
supply must be firmly good enough to finish this updating , power outages would contribute to a failure .
