[ROM] Mecool M8S PRO W Stock & Nano Nexus ROM (Android 7.1)
Originally posted by Magendanz View PostIn the spirit of the Pure Nexus Project, these Nano and Stock Nexus ROMs prove that less can be more. The goal is to keep true to Google's vision and use the bare minimum of OEM or third-party apps or add-ons, which can be added à la carte by the user as needed. These ROMs also serve as a foundation for TVStock Nexus ROMs, which deliver the pure Android TV experience using the Open GApps TVStock Package.
Stock Nexus variant includes:- Open GApps Stock Package
- All contents of the Nano Nexus variant
- Open GApps Nano Package
- Google Now Launcher (replaces Lighthome Launcher)
- Google Chrome Browser (replaces AOSP Browser)
- Google Legacy Camera (replaces AOSP Camera)
- Google Desk Clock (replaces AOSP Desk Clock)
- Google WebView (replaces AOSP WebView)
- Terminal app from LineageOS
- TWRP Recovery 3.2.1-0 by TeamWin
- Updated to the latest Mecool M8S PRO W OEM firmware (20180126.191102.V0928),.
- Wake from sleep is now working, and taking the expected 2-3 seconds.
- Updated to TWRP Recovery 3.2.1-0 with latest OEM kernel.
- Updated to latest OpenGApps build (20180311).
- Updated to the latest Mecool M8S PRO W OEM firmware (20171030.152444.V0619),.
- Updated to latest OpenGApps build (20180121).
- Based on the latest Mecool M8S PRO W OEM firmware (20171017.112143.V0619), stripped to Android stock bits and the latest Open GApps.
- Added local update and backup option from Settings->About->System update based on Amlogic stock OTAUpgrade app.
- Added additional options (Reboot & Sleep) to global action menu that displays when you press and hold the Power button.
- Added support for all HID devices (e.g. remotes, gamepads, etc.) on latest Nougat firmware for Nexus Player, NVIDIA Shield TV & Xiamoi Mi Box
- Nexus splash logo with stock Nexus boot animation
- Clicking on Vision Settings in the setup wizard will launch an unsupported activity in Settings.
- You can enable the nav bar in Settings->Display->Statusbar, but may need to toggle back and forth before it will show.
- Nano Variant: BURN PACKAGE (921MB), OTA UPDATE (471MB ZIP file)
- Stock Variant: BURN PACKAGE (1.42GB), OTA UPDATE (804MB ZIP file)
- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
- The underlying OEM firmware for this build is pre-rooted, so this is too.
- The updater is signed, and so can be installed in the Update app, the stock recovery, or TWRP. It's designed for incremental updates, since user data is preserved. If you're installing for the first time, you should include a data wipe.
- The safest bet is always to install the full Amlogic burn package with USB Burning Tool. With no reset switch, you can trigger USB detection by typing "reboot update" in a terminal window.
- The local terminal app shows after being enabled in Settings->Developer Options. (This must be revealed by clicking Settings->About->Build 7 times.)
- Flash ROMs at your own risk and always remember to back up your data first. The burn package includes a factory reset.
- Maarten Fonville at Open GApps
- Pure Nexus Project
- LineageOS
- TeamWin
- GearBest for sample hardware
- Your support is always appreciated! Just click here.
Hi @Magendanz, installed M8S_PRO_W-ota-20180802.182556.V0213 stock (very good by the way) and wanted to root it, so installed twrp via update app with signed zip but it now always says cant mount /system and /data and others.
Tried a few other twrp versions and still the same error as with twrp from your rom 20180311.
Stock recovery of M8S_PRO_W-ota-20180802.182556.V0213 launched from sdcard works fine, stock recovery from 20180126.191102.V0928 (previous version) does not.
Do you know whats going on? Recommend any twrp version i may try?
Installed NANO version, on a X96mini - 2/16 GB, but only 1/8GB registered in the info-box
Any way to "open up" the rest of memory/storage ?
Should I do something to the flashfile, or is there a 'setting' ?
That's in the DTB, which I pulled directly from the OEM firmware. There are 1G and 2G versions, and the bootloader should select the correct one at runtime.
If anyone has a link to the latest OEM firmware release, I can update with that to see if it fixes the problem. It's been a few months since I've had the time to look at this.
Dear Guest . I am also one of the owner of Mecool M8S Pro W with the blue motherboard and latest revision, where the flash memory is completely different. This is why we cannot install your custom roms and the procedure hangs at 7%. Another thing to note is that the new boxes are shipped with Android 7.1.2 like following: M8S PRO W-userdebug 7.1.2 NHG47L with version 20180724.093649.V0213 . I asked supplier and they provided following ota file : https://mega.nz/#F!jE9DUTDY!vkLtjn8UeCeM20_iXIKvbQ . Do you think you could perform your magic and create a stock & nano nexus rom based on this firmware?
Guest
Originally posted by denexo View PostDo you think you could perform your magic and create a stock & nano nexus rom based on this firmware?
Well, as a general rule I can't build custom ROMs for devices that I don't have, since I need to be able to at least do some basic smoke tests. In this case, it will depend on how much they've actually changed. If it's just an updated device tree, then I'd probably only need someone with the new hardware willing to be a beta tester. Anything more involved than that would be problematic.
Hi Guest . I was looking to flash my M8S Pro W with the Android TV version of the firmware ( it came with standard Android ) but I'd like to put the newer version if possible. Any progress on the 20180802 release ?
I can help if needed as I work in IT and have a bit of experience with Linux and Android.
Originally posted by denexo View PostDear Guest . I am also one of the owner of Mecool M8S Pro W with the blue motherboard and latest revision, where the flash memory is completely different. This is why we cannot install your custom roms and the procedure hangs at 7%. Another thing to note is that the new boxes are shipped with Android 7.1.2 like following: M8S PRO W-userdebug 7.1.2 NHG47L with version 20180724.093649.V0213 . I asked supplier and they provided following ota file : https://mega.nz/#F!jE9DUTDY!vkLtjn8UeCeM20_iXIKvbQ . Do you think you could perform your magic and create a stock & nano nexus rom based on this firmware?
I think I have similar version of Pro W box as you have. No Rom from this forum works and I don?t know how to install back the stock ROM without usb cable...
Thanks.
There are currently 2334 users online. 2 members and 2332 guests.
