Hello,
I have the alphawise H96 pro + since one week, but i have a big problem. When i play movies with 5.1, i have no sound. Others movies are ok.
The box is connected with tv in direct by hdmi.
The rom is wisdom2 q201_9377-userdebug 7.1.2 NHG47L 20171020
Do you have an idea ?
Hello,
Christophe
Hi ,
this is not really a Problem , what App did you use , not all Apps and Systems support it ,
did you try KODI or SPMC Mediacenter ??? , maybe you must flash one of the Roms for
Hi, I had the same problem, the only player that worked was the Bsplayer that I downloaded directly from Google play. The only problem is that it does not support 4k video.
I wanted to use mx player but could not use ac3 5.1 sound on it myself by installing the required codecs.
I watch movies from my computer using the network service.
Kodi with software audio rendering also "solves" the problem.
