H96 Pro H2 Stick Wifi question
I wanted to upgrade from the fire stick to this one, but when I plugged it into my hd projector, I found that the wifi speed was lacking. I only get about 20Mb down as opposed to the firestick's 70Mb down. This makes using it as a streaming device impossible. I'd like to see if I can plug in a USB wifi adapter that supports AC speed, but I'm not sure if it's even possible. Would the H96 even recognize the adapter. And would it bypass it's own adapter if it did recognize it? Any help would be greatly appreciated.Tags: None
Originally posted by eric859 View PostI wanted to upgrade from the fire stick to this one, but when I plugged it into my hd projector, I found that the wifi speed was lacking. I only get about 20Mb down as opposed to the firestick's 70Mb down. This makes using it as a streaming device impossible. I'd like to see if I can plug in a USB wifi adapter that supports AC speed, but I'm not sure if it's even possible. Would the H96 even recognize the adapter. And would it bypass it's own adapter if it did recognize it? Any help would be greatly appreciated.
maybe the PCB connection is bad soldered , bad cable broken ??? , bad Antenna (only Stick) ,
no external Antenna , maybe modding helps , maybe you only have to change the Rom , if i am
not wrong you can use one of the CustomRom from here .
good luck / gefattern
There are currently 2832 users online. 0 members and 2832 guests.
