Unable to install ROM
    after trying to installing a custom rom for my clone beelinkGT1 box, i accidently wiped everything on the tvbox from twrp interface. It last just TWRP wich i installed before.
    I tried to directly install a .img firmware from TWRP but at each try it says " Size image is larger than target image ".
    I also tried to install a update.zip file but it neither works.
    Also tried to boot .img directly from usb key and it didn't worked.
    I watched lot of tutorials but in their cases, the rom wasn't wiped so i don't know how to proceed. ( i tried their methods but doesn't work )
    Can someone please help me i'm totally disperate
    Originally posted by noipo View Post
    Hi ,
    you must install completly new , full Stock or CustomRom . with Pc ,
    ask if you need more Help .
    greetings / gefattern
      Thanks for the fast reply
      So i can’t do anything with a microsd card with a’ .img bootable on it?
      Thought that without USB male/ male it was possible to install rom
        So tried with the usb burning tool and install world cup drivers :
        I nticed smthng strange, when i plug into the computer without the recovery mode my computer makes the noise to say its connected but it dont show on the tool.
        Then, when i do the same in recovery, nothings happen.
        A solution ?
          Hi ,
          if you never have flashed a Box new please first look some YT Videos
          how to flash Amilogic / your GT1 , look here :
          hope you get it , greetings / gefattern
            i'm not a noob + i told you that i could'nt start the box further than the boot logo
