Long time listener. First time caller.
I recently took ownership of an Amlogic S905 p200_2g Android box for the grand total price of free. It's currently running Andoird 5.1.1 after a manufacturer OTA update.
Unfortunately, it is not a box from a well-known manufacturer. I have found others online that look similar to this one, however.
Anyway, I would love to update it to Android 6 using Magendanz's ROM here: http://freaktab.com/forum/tv-player-...-tv-nexus-roms
However, he warns that updates may cause wifi not to work as the ROM only has drivers for specific wifi chipsets.
How do I verify which chipset is installed on the board? And what other things can I check to see if his ROM is compatible with my Android box before attempting to flash?
Some background: I'm fairly inexperienced with Android but I can get by in Linux for the most part. The dmesg command doesn't work in terminal on this box, so I can't identify the wifi chipset that way. I can probably crack open the case if necessary, but I'd rather avoid it if at all possible.
Cheers and thank you.
