PMID701C (ONLY, for now) Elektricity ROM .40 coming soon....
Just as soon as I can get some FTP issues sorted out. I really think everyone's gonna be pleased with the speed bump this new version gives our PMID701C tablets...It screams compared to .031 Elektricity ROM and roars past stock, for sure.Tags: None
Originally posted by notpod View Postand looking forward to trying it out. I have moved on to a Hisense sero 7 pro for tinkering but plan to use my 701C as a psuedo chromecast device.
Originally posted by morlog View PostP'm about to give the ne version a try, been enjoying .31 so far.
Originally posted by elektrik View PostGood. I think you'll like the .40 version better, although the only thing I've noticed is that firefox chokes if I open too many windows (but then, Firefox chokes on this tablet on the STOCK rom with too many windows lol).
I'm liking 4.0 so far. Really like the minamalists aproach to what software is on there to start.
I would stress the letting your tablet sit for a bit after you flash it with the new rom.
Another thing i would recommend is to update super user, busybox, and the apex launcher about an hour after you flash the rom in this order.
1. Flash the rom.
2. Wait a half an hour to an hour for the rom to burn in.
3. Log into wifi network
4. Update Super Users binary inside super user
5. Update Busybox inside of busybox
6. Log in to google play or create an account
7. Update SuperUser in google play
8. Update Busybox in Google play
9. Update Apex launcher in Gppgle Play.
I flashed it too my tablet more than once and the above method is what worked the best for me for this version. If i remember correctly i had to do something similar in the previous version.
Its just a matter of updating things in the right order and has nothing to do with the quality of the rom which is superb.
Originally posted by morlog View PostI'm liking 4.0 so far. Really like the minamalists aproach to what software is on there to start.
1. Flash the rom.
Originally posted by elektrik View PostSo I'm curious, when you updated the SU binary from inside super user, did you loose root access? you should check and find out, because when *I* do that, I lose root.
You have to run the update a few times until it does the update without errors. It has to give itself superuser priveledges in order to update.
Originally posted by morlog View PostNo I don't lose root. I update the binaries as they were the legay binaries when I checked.
Originally posted by elektrik View PostHuh...interesting...Ok I'll keep trying then..
Originally posted by elektrik View PostI tried to run the update several (at least 6) times and every single time the upgrade 'failed' and I lost root, so unless you want to copy the SU binary from your tablet and send me a link so I can drop it in my ROM and test, I'm afraid I'll be keeping what is in there.
I wish i knew more about android, the way it handles memory is strange.
Originally posted by morlog View Postheres the su binary https://www.dropbox.com/s/0hf3atgp5rdku2k/su
There are currently 1494 users online. 0 members and 1494 guests.
