printed on it. Unfortunately I have installed SuperSu and the box got bricked as there is no display and only blue led blinking. Reset switch is not working and no display or recovery mode. Burn card method for reflashing the rom is also not worked. With a lots of efforts and hundreds of errors, somehow i have managed to recognize the box in Windows PC and USB Burning tool 2.8.0 and burned the firmware released on 10102017. It was burned successfully but the box still not booted, then retried with special firmware, which is designed by SHONK for that particular boxes with LPDDR3 Ram. It also burned successfully but still no display!!!!! so please suggest me what should I do now. All of members valuable suggestions are cordially appropriated. Thanx.
How to unbrick Banggood H96pro plus CZ_S32_V5
Hallo everybody. I have a H96 pro plus box bought from Banggood. It has a blue pcb and CZ_S32_V5 and 29-8-2017
printed on it. Unfortunately I have installed SuperSu and the box got bricked as there is no display and only blue led blinking. Reset switch is not working and no display or recovery mode. Burn card method for reflashing the rom is also not worked. With a lots of efforts and hundreds of errors, somehow i have managed to recognize the box in Windows PC and USB Burning tool 2.8.0 and burned the firmware released on 10102017. It was burned successfully but the box still not booted, then retried with special firmware, which is designed by SHONK for that particular boxes with LPDDR3 Ram. It also burned successfully but still no display!!!!! so please suggest me what should I do now. All of members valuable suggestions are cordially appropriated. Thanx.Tags: None
Blue light no longer blinking( members indicated blinking is bad power brick?)
Is it now on Android 6 or 7?
Have you tried SCV1 (6) SCV4 (7)...just asking... If stock was Android 6, when Flashing from Android 6 to 7(and vice-versa) did you select Erase Bootloader? (necessary)!
Just random guessing with info provided.
Originally posted by ReaperMan View PostBlue light no longer blinking( members indicated blinking is bad power brick?)
Amlogic USB Burn Tool, it should make no difference..but...installation and detection worked best(for me) v2.05.15?? Had to do a deep clean uninstall to get back to fresh start!
Collection of versions via bluesmanuk : https://www.dropbox.com/s/hlu6kddbi4...Tools.zip?dl=0
If you you have nothing to lose, try SCV1..or the Beelink Gt1 Ultimate SCV1 firmware(compatible?)
P.S. You may try to flash checked > Erase Boot Loader then re- flash and un-select > Erase Boot Loader. (Very old problem that I had with an OTA flash)
P.P.S. I've had bad results with SD Card Burn Tool.
P.P.P.S. Avoid using a hammer!
Other members may have more useful suggestions
There are currently 2356 users online. 0 members and 2356 guests.
