Thanks in Advance!
OTT M8S No Power
OTT M8S No Power
A friend of mine gave me his OTT M8S box as it does not power up. I have tried different power cables and still nothing. I want to try and flash the factory firmware back to it but I am not sure which file I need. I have attached a pic of the board is someone could please help me out. This could even be a Clone.
Thanks in Advance!Tags: None
I've had similiar problem with mine M8S. Using hints from http://freaktab.com/forum/tv-player-...0-out-of-ideas I've managed to recover it and install Tronsmart ROM. Basically, you need USB A-A cable (both end are the same), plug it in the leftmost USB on box and on your PC (there's no need for power, it's supplied via USB). Install USB Burning Tool 2.0.5.15 (maybe you'll need different version, this one worked for me). Import appropriate image and click Start.
Hope this helps you.
There are currently 1860 users online. 1 members and 1859 guests.
