My problem: I have an apparently soft-bricked COOLEME MB3 box. 2G/32G, probably ddr3. Samsung emmc(?) not the Forsee chip. Otherwise the board looks identical to the pictures I've seen of the Alphawise S92. It runs Armbian fine from the microsd. The Samsung chip on the board is a BGA and the board has no exposed pins nor pads for shorting.
It never finished booting correctly on the very first power on, and I've been tinkering with it ever since. I managed at one point to flash one of superceleron images to it, but I apparently put the wrong bits on there somehow and now no attempt at flashing by any of the well-documented methods works. I'm using a 3A 5v power supply rather than the supplied 2A.
Also, the emmc is not visible from Armbian (the probe fails) and I'd like to eventually get that working. I've soldered up a header to the UART and an FDTI USB to serial adapter, and captured the output of a burn attempt from the USB burning tool (press & hold the button before powering up, etc.).
I was trying to burn this alleged factory image referenced on the product page at banggood.com:
Here's the UART output while trying the USB burner tool. It always fails exactly this way. Anyone got any ideas? Thanks!
GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:800;NAND:81;SD:800;USB:8;LOOP:1;EMMC:800;NAND:81;SD:800;USB:8;LOOP:2;EMMC:800;NAND:81;SD:800;USB:8;LOOP:3;EMMC:800;NAND:81;SD:800;USB:8;0.0; TE: 22422782 BL2 Built : 19:58:22, Aug 31 2016. gxl g54c8aee - xiaobo.gu@droid05 set vdd cpu_a to 1120 mv set vdd cpu_b to 1050 mv set vddee to 1000 mv Board ID = 8 CPU clk: 1200MHz BL2 USB DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0+1 @ 912MHz - PASS Rank0: 1024MB(auto)-2T-13 Rank1: 1024MB(auto)-2T-13 0.0; TE: 22862226 BL2 Built : 19:58:22, Aug 31 2016. gxl g54c8aee - xiaobo.gu@droid05 set vdd cpu_a to 1120 mv set vdd cpu_b to 1050 mv set vddee to 1000 mv Board ID = 8 CPU clk: 1200MHz BL2 USB 0.0; TE: 22949064 BL2 Built : 19:58:22, Aug 31 2016. gxl g54c8aee - xiaobo.gu@droid05 set vdd cpu_a to 1120 mv set vdd cpu_b to 1050 mv set vddee to 1000 mv Board ID = 8 CPU clk: 1200MHz BL2 USB Load fip header from USB, src: 0x0000c000, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from USB, src: 0x00010000, des: 0x01100000, size: 0x0000d600 Load bl31 from USB, src: 0x00020000, des: 0x10100000, size: 0x00015400 Load bl33 from USB, src: 0x00038000, des: 0x01000000, size: 0x000a9c00 NOTICE: BL3-1: v1.0(debug):2e39a99 NOTICE: BL3-1: Built : 16:36:21, Sep 20 2016 aml log : bl31 normal boot ! [Image: gxl_v1.1.3154-065f772 2016-09-29 14:08:54 yan.wang@droid05] OPS=0x82 ca f0 8c 5c 7a 4e 9f ae 6f 23 d 98 [23.253097 Inits done] secure task start! high task start! low task start! INFO: BL3-1: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader ERROR: Error initializing runtime service opteed_fast INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01-g871cd3d (Jun 17 2017 - 11:31:08) DRAM: 2 GiB Relocation Offset is: 76ec9000 InUsbBurn [MSG]sof Set Addr 5 Get DT cfg Get DT cfg Get DT cfg set CFG ID[16] tplcmd[ echo 12345] 12345 [MSG]ret = 0 [info]success BULKcmd[ low_power] [info]success ID[16] tplcmd[ download mem dtb normal 88064] [MSG]Down(mem) part(dtb) sz(0x15800) fmt(normal) [MSG]totalSlotNum = 0, nextWriteBackSlot 2 [info]success [MSG]Burn Start... [MSG]load dt.img to 0x0000000001000000, sz=0x15800 [MSG]Burn complete BULKcmd[download get_status] [info]success BULKcmd[disk_initial 4] Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxm platform: q201 variant: 2g dtb 0 soc: gxm plat: q201 vari: 1g dtb 1 soc: gxm plat: q201 vari: 2g Find match dtb: 1 start dts,buffer=0000000007700000,dt_addr=000000000770b000 parts: 11 00: logo 0000000002000000 1 01: recovery 0000000002000000 1 02: rsv 0000000000800000 1 03: tee 0000000000800000 1 04: crypt 0000000002000000 1 05: misc 0000000002000000 1 06: instaboot 0000000020000000 1 07: boot 0000000002000000 1 08: system 0000000080000000 1 09: cache 0000000020000000 2 10: data ffffffffffffffff 4 [MSG]run cmd [store disprotect key; store disprotect hynix] [store]disprotect key disprotect hynix emmc/sd response timeout, cmd8, status=0x3ff2800 emmc/sd response timeout, cmd55, status=0x3ff2800 emmc/sd response timeout, cmd1, status=0x3ff2800 EMMC init failed boot_device_flag : 1 set wlan gpio pin 6. set bluetooth gpio pin 17. Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc. init bus_cycle=6, bus_timing=7, system=5.0ns reset failed get_chip_type and ret:fffffffe get_chip_type and ret:fffffffe chip detect failed and ret:fffffffe nandphy_init failed and ret=0xfffffff1 NAND init failed device_boot_flag=2 [store]ERR:FAILED in get_device_boot_flag cmd [store] init failed [info]failed:
