I messed up my box by installing supersu... So i was looking for rom... My box doesnt say "C" anywhere... So i flashed the non-c rom... Neither does it say AZW so i thought its mecool... Anyway, after flashing the box was slow as a snail... Everything would keep crashing... So obviously i flashed wrong stuff. Also i noted that ethernet wasn't showing up. Investigating down the line i came here on freaktab to find that mine is probably AZW & C because on my packing it said 100mbps lan. I flashed this rom & everything became normal.
for flashing i used tool version 2.0.8. didnt kno then tat theres a 2.0.9... anyway, i hit START on flash tool, kept the reset button pressed, powered ON & plugged into PC... First i tried without power & it would detect but fail @2%... Also, both usb ports behave the same for me but the one beside microSD behaved better.
Now some points i think should be integrated into next update...
Integrate a superuser management tool... I tried installing supersu which messed up my box in the 1st place.
Please remove the inbuilt file manager & pre-install es file manager cause the inbuilt one cant even read NAS/SAMBA drives.
The inbuilt kodi & cpuz saying 1280x720? So if i play a 1080p or 4k, the vdo would play natively at 720p & then be upscaled to hdmi output resolution? (4k in my case)
Amazon prime not running even in HD!
Youtube running @720p max!
Though it has 5g wifi, speed is too slow like 6mB/s down & 1.5mB/s up... Whereas mibox-3 can do 11mB/s down & 6mB/s up.
Probably due to this slow wifi, i cant run HD movies from my NAS thru vlc/archos.
I have a 4k tv... My mi-box-3 runs utube at 4k... Amazon runs at full hd... And that box just has a s905x-H... I dont understand what i gained by buying this octa core s912... Price is almost the same...
