Tictid T10 Pro rom?
Originally posted by Licentia View PostDoes anyone have a flash rom file for the Tictid T10 Pro?
is it a S905 like this one here :
https://www.****.com/itm/2GB-DDR3-16...75.c100623.m-1
can you confirm that the Wifichip is the same as in the Link discribed ???
maybe it is possible to find a CustomRom for your Box ???
it looks like the Bqeel T10Pro is similar , maybe a Rom of this Box
works too , maybe you can find a working Rom on one of this Pages
for your Box :
http://freaktab.com/forum/main-categ...ge-many-models
first Post Links .
good luck / gefattern
Thank you for your reply. I can't see the link you posted due to the ****.com in the url, so I can't confirm. The box has 2GB of ram and a 16GB emmc. The processor is a S905 with a RTL8189 wifi chip. The specifications are pretty similar to the Bqeel T10 Pro. However, I wasn't able to find a rom for that one either.
Originally posted by Licentia View PostThank you for your reply. I can't see the link you posted due to the ****.com in the url, so I can't confirm. The box has 2GB of ram and a 16GB emmc. The processor is a S905 with a RTL8189 wifi chip. The specifications are pretty similar to the Bqeel T10 Pro. However, I wasn't able to find a rom for that one either.
yes the Page showed the same Box and Specs , but not sure with what Rom you can restore
your Box , if you know a Box has the same Specs , you can try to find a working StockRom
from here :
first Post , good luck / gefattern
There are currently 4403 users online. 3 members and 4400 guests.
