Hi All,
I hope if any one can help me out with this request! I have installed (Hph Tv Launcher) to replace my default launcher for H96 - P S905x DLP Mini Projector Android 6.0.1. I have two issues
1. After I installed Launcher I can't add the HDMI in icon for easy access to home screen. is there an addition apk that I need to install to fix this?
2. the time and weather not in sync with system and I cant find the config app to fix this issue.
you are right! I did try to flow the information in the site for problem 1 but this is nothing to do with hdmi in icon. I know it's there but how to extract the apk from the default launcher..
the HPH Launcher is the StockLauncher of the Rom Mo123 makes , so only Way is to extract
from Rom , or maybe Mo123 can upload , but i am not sure if his fixed Version works on other
Boxes ???
greetings / gefattern
That is right! maybve it will not work but we don't know until we test it .. if there is another launcher that will provide us hdmi in access through the homepage will be appropriated
Hi ,
then u only can test , ever tested the Ugoos launcher (my UT3 has HDMI in too)(so maybe) or some others ???
Hi All,
Thanks.
You can add any app to the bottom shortcuts if you use the '+' button.
If your device uses the same keylayout as Rockchip devices and you can press the menu key, it will allow you extra customization for the launcher.
You are trying to use Rockchip apps on Amlogic devices which might not work.
I know eg. in Ugoos UT3+ devices the HDMI input support only works with their app, firmware has to have support for it and the remote's buttons and drivers need to be re-programed to support the HDMI function.
So maybe thje HDMI-IN support in that S905x device uses propriety launchers or HDMI-IN app/code that can only work optimally with it's stock firmware and apps.
The latest launcher with working weather only works on Nougat firmware and you also need Omniweather app support and app included.
The Yahoo api for the weather changed and is not working in Marshmallow at this time.
