https://chinagadgetsreviews.com/down...b2-tv-box.html
BB2-ota-20170915.132236.V0619
It seems to be working quite well!
Steps:
- Download the latest OEM firmware ROM BB2-ota-20170915.132236.V0619.zip which is Android 7.1.1
- You now have a few different options to install and upgrade it:
- Put the zip file in the root of a USB stick or micro SD card
- Install the new firmware zip file by booting into recovery
- Install from a functional TV Box using the Update icon or via the settings, About media box and into the OTA update. Click Local Update and the zip file will be displayed in yellow, click on it and then click Confirm. If you want to retain your data do not check the two boxes, for a clean install rather check those boxes and then push Confirm
- Unplug the power plug from the back of the TV box.
- Copy the zip file to the root of the USB stick and plug into the TV Box.
- Push and hold the on/off switch on the front panel and plug the power plug back into the TV Box while still holding the button in.
- Keep holding the button until the Android robot appears laying on its back, only then release.
- You are now in recovery mode and the recovery menu should display in the left top of the TV screen.
- Use the remote to select “Apply update from EXT” and push the OK on remote
- Next select “Update from udisk” (or sdcard if you used the micro SD) with remote and push OK on remote.
- Next select the file: BB2-ota-20170915.132236.V0619.zip with remote and push OK on remote.
- “Installing system update” will show on screen under a large ring, with progress bar under the robot and messages in left bottom corner.
- When the installation is completed, the Android robot again appears laying on its back with a red flag and progress message says “Installation for udisk completed”. And the recovery menu will again show in the left top corner.
- Next select “Reboot system now” with the remote and push OK.
- The BB2 TV Box will now reboot into the new Android 7.1.1 installed.
- Note: It seems as if SuperSU 2.79 is not compatible with 7.1.1, but not sure. It does not update the binary causing a freeze at the boot logo.
