H96 Pro - H3 TV Dongle Amlogic S905X Android 7.1 2/16GB Dual WiFi BT 4.0
    Specification
    Core: Quad Core
    CPU: Amlogic S905x
    GPU: Mali-450MP
    RAM: 2G RAM
    ROM: 16G ROM
    System: Android 7.1
    Type: TV Dongle
    Processor: Amlogic S905
    TV Box Features: Gaming,Portable
    Decoder Format: H.265
    Video format: 4K
    Bluetooth: Bluetooth4.0
    Interface: HDMI,Micro USB,OTG,TF card
    Power Supply: USB Port
    Power Type: External Power Adapter Mode
    Power Adapter Output: 5V 2A
    Package size (L x W x H): 12.30 x 10.20 x 5.60 cm / 4.84 x 4.02 x 2.2 inches
    Package weight: 0.2500 kg
    Product size (L x W x H): 10.00 x 8.00 x 4.00 cm / 3.94 x 3.15 x 1.57 inches
    Product weight: 0.2000 kg
    Package Contents: 1 x TV Dongle, 1 x HDMI Cable, 1 x Engllish User Manual, 1 x Power Charger, 1 x Mini PC
    Sorry if a silly question. Am considering one of these. Is there a guide for running libreelec via micro sd on it? A bit unsure of it as it's a dongle rather than a box.
    Cheers
    Simon
        Lets have a look at the H96 Pro - H3 TV Dongle Amlogic S905X Android 7.1 2/16GB Dual WiFi BT 4.0
        Much the same as the other H96 Stick/Dongle only a Amlogic 905X
        Main Features:
        ● The latest 802.11 a / b / g / n WiFi standard: get 3x faster access and more reliable streaming for your home computers and mobile devices
        ● Simultaneous dual-band networks, 2.4GHz and 5GHz
        ● HDMI greatly increases the transfer rate
        ● 2GB RAM + 16GB ROM
        ● The TV Box with Amlogic S905X chip, the use of 64 bit 4 core CPU and 2 + 16GB memory, customizes characteristic Android 7.1 system
        ● Support hardware decoding H.265
        ● BT4.0, power saving, low cost, 3ms low latency
        Lets Have a close look
        The Box
        What's in the box
        Bit of a look around
        One side
        The Other side not much of a heat sink
        Nand maskrom location
          As seen above a thin tin Heatsink this may be trouble, may need some creative cutting and a Heat sink to keep the cool
          Startup was OK, WiFi and Google setup ok, BT detects fine.
          Slow at Downloading and installing Apps at this stage..
          Has Root access with SU, upper and lower bars
          Seeing some temps in the the 80C doing just basic tasks a bit crazy
          Settled after a few restarts etc
          On with test etc..
          UI, Installed Apps, added Reboot a must to have.
          System Info
          DRM InFo L3
          Ram and Storage Truth
          CPU-Z 3xFrames
          Geekbench CPU
          More >
          http://browser.geekbench.com/v4/cpu/6404912
          Geekbench Compute
          A1 SDBbench
          Gearbest
            nova launcher unfortunately settings has stopped
            When Firefox restarts
            Is there a software to solve these problems
              Is anyone making a custom ROM for this? I've seen ROMs for the S912 version.
                I just replaced the thin heatsink with two mosfet heatsinks for the Raspberry Pi and dropped 15c, they fit inside the cover as well.
                  As mentioned before, an Android TV ROM for this version of the stick would be highly appreciated. I'm guessing someone who knows how to port ROMs can easily port a ROM from another S905X box.
                    As Found:
                    H96 PRO H3 ANDROID 7.1 2GB/16GB TV DONGLE UNROOTED FIRMWARE 20180404
                    Source blog.geekbuying
                      Much appreciated, but how do I install that when I have TWRP? I've been trying for a while now but all I get is that the file is larger than the target device.
                      EDIT: USB Burning Tool actually worked for once, thanks.
                        I can not go to the recovery menu, so I can not install a root, realized that the new fw are s905x16 and the one that came in our era s905x13, the same as the MXQ PRO +?
                          As Found
                          H96 PRO H3 2GB/16GB S905X TV DONGLE FIRMWARE UPDATE 20180622
                          blog.gekbuying
                            I currently just received this product as a bundle with a projector.
                            I am so disappointed with this unit.
                            Current issues:
                            -WIFI intermittent issues, sometimes load, sometimes hang, sometimes no internet connection at all. Tried Youtube, Chrome, Kodi etc.
                            -Tried to browse my local SMB network with ES explorer, doesn't load
                            -Tried 2.4ghz and 5ghz, same issue
                            -Tried static IP
                            -Tried shifting positions, put beside router etc.
                            What I am hoping for:
                            -Some miracle quick fix suggestion
                            -New custom firmware that will fix these issues and boost up the overall speed of the ROM
                            -Able to use LAN cable to on it
                            This the current firmware that I can gather from CPU-Z:
                            The thermals are good, idle 40+C, load is around 60+C
                            After browsing around in this forum, it's highly likely I have a defective unit as most users don't have such problems.
                            Also was thinking to try the USB to Ethernet adapter but the older version of this stick didn't have the drivers, what are the chances this H3 model is updated with it? Anyone able to test?
                            Thank you
