NEXBOX A95X-B7N
    NEXBOX A95X-B7N
    i have the Nexbox A95X-B7N with amlogic s905x cpu and 1gb of ram and 8gb of rom.
    i have already download the original IMG for recovery original firmware and android 6.0.1 (installed for default in this model).
    but i have a problem:
    I customize original IMG with "Customization Tool v2.0.8" in the level 2 of tmp folder i delete some pre-app like as facebook, twitter, youtube and i build new IMG
    Then i flash this IMG to my box whit "USB Burning Tool v2.0.5.15" and the operation complete successful, but when i power on the box after the boot the system crash and show me prompt screen.
    If i try to flash with original IMG the box restart very well and start with all functions.
    Why? The Customization Tool is not just version?
    i wait your response.
    Hello,
    I think your Problem is the Customization Tool 2.0.8.
    It can extract the Image but have Problems with packing of the Image.
    Try it with this 2.0.10 Version from here --> http://freaktab.org/04f1cf352c614119
    Neomode
      i try in few minutes and write here the response
        neomode not work...
        my steps are:
        1. download from your link the Customization Tool v2.0.10
        2. Open the original IMG
        3. Delete all APK from "CustomizationTool_V2.0.10\tmp\level2\system\pre_a pp"
        4. Save the new IMG
        5. Open "USB Burning Tool v2.0.5.15" and load in the BOX
        6. Operation complete without error
        7. PowerOn the BOX and after boot you can see this: https://ibb.co/g7Bkpb
        have you and idea?
          Okay good I see your Problem.
          Now you need to go deep in the Rabbit Hole and do it with Linux.
          It done cases the tool you use can't make an prober Image File.
          ​​​​​​You need at least an virtual machine with Ubuntu 14.04 LTS and some tools from here:
          Utils/Tools for development. Contribute to khadas/utils development by creating an account on GitHub.
          You need aml image packer and the tools simg2img and img2simg.
          also install yourself the midnight Commander an file manager for the terminal.
          open up an terminal and become super user with sudo su
          First extract the firmware with the Aml tool after that you convert the system. Partition to IMG with simg2img
          simg2img system.partition system.img
          now make an Directory called system
          Now you can mount it with mount -o loop system.img system
          After that remove what you want
          Unmount system
          Transfer it back with img2simg system.img system.partition
          Then repack the firmware Image with aml tool and burn it.
          Neomode
            i need to install virtual machine with linux on my windows.
            can i try on apple os?
              No you need an Linux. But you can install an VM there also.
              Neomode
                Shit man ...... im waiting the 2/16 version
                is there somewhere a complete tutorial how to root this thing?
                when i ask the gearbest if is rooted and they anwer me no i freaked out......
                then i registed here freaktab nice i like it
