A1 708NO 4G+16G / 32 G
Current version :A1_708N0 based on :A1_707N0/706N0........ android version :7.1.2 fits for:RK3328 DDR4/DDR3/LPDDR3 4G+16G/32G WIFI&BT: 2.4G/5G Ethernet:1000M USB burning tool : https://beelink-my.sharepoint.com/pe...f8626690ddb17d USB zip: https://beelink-my.sharepoint.co ... 009aee17e91e99ebc8e SD zip: https://beelink-my.sharepoint.com/pe...028b4477d3759b Improvements: 1. The FileExplorer app has been removed . 2. The shortcut of FileExplorer has been changed for Gallery . 3. The problem that the midea button gives no response has been improved . 4. We have updated some APPs , such as bee files manager , AppMarket . 5. The OTA from current version to 708N0 has been available for you now . Some tips for updating : 1. USB updating : 1)Install the DriverAssitant_v4.5 first and double click the DriverInstall.exe , then you need to choose the "install the driver"option to finish this installation ; 2)Open the USB bunning tool which is named FactoryTool-v1.43e and then double click the FactoryTool.exe ,now it's time to click the "firmware"to load it well . 3)Click the "start" and hold the reset button still to connect the double USB cable , then you can take it easy to wait for the updating . 2.SD updating : 1.Format your sd card with the FAT32 fromating style . and then you need to copy the update.zip file to the root of the SD card ; 2)Insert the sd card to the port ; 3)Wait for the updating pop news and choose the update option . you need to make sure that Power supply must be firmly good enough to finish this updating , power outages would contribute to a failure . you can contact with me if you meet some problems . email : [email protected] / skype : +86 18772960513Tags: None
There are currently 1998 users online. 1 members and 1997 guests.
