Chrome fix for Copy/Paste and Long Press options.
    This error is not singular to Alfawise or a particular version of Android.
    Current releases of Chrome V58 -- > V65 cannot screen drag or long-press for options.
    I spent hours trying the different versions, O.S. variants, settings and Chrome://flags. Chrome home screen has these features, while, progressive web pages have options repressed.
    Make sure auto-update is turned off in your Playstore account.
    Get Chrome 57.0.2987.132 (choose the one that best suits your O.S.)
    https://www.apkmirror.com/apk/google...7-132-release/
    After much searching on Google and Chrome support forums... ( Expert - Community Specialist) have a canned reply of "clear cache/data or re-install Chrome"...with all the request over the past months, Google seems to have removed these features with purpose.
    Maybe a future Chrome will work.
    If so...share your results.
    Thank you very much Reaper Man.
    I was trying to figure out "copy/paste" options on Chrome for about a month and finally came across your post and your solution worked.
    Thanks again.
