When I try to format it gives failure such as on the attached first photo.
Then I tried to flash rockchip batch tool it says "DOWNLOAD IDB FAIL" such as on the second photo.
I also tried with the tool which is provided by the seller from aliexpress but is giving the same fail as on the third photo.
Any ideas to fix this problem?
is there specifically RK3228B tool or recovery img?
