Trying to find format of config file after unpacking aml_upgrade_package.img with Amlogic Customization Tool 2.10
I have worked allot now with the Amlogic Customization Tool 2.10 and it works great. I noticed a file in located in <installdir>\tmp\level2\system\package_config called "config" and have tried renaming it to .jar, .zip, and .dex and then using respective decompiling tools and none have worked. Does anyone have a suggestion on what this might be or how to find out what it is? I have attached the 2K file with the extension changed to .txt. The original has no extension..Tags: None
There are currently 2347 users online. 0 members and 2347 guests.
