whitch rom to flash?
    hello i have this version of h96 pro+ https://www.geekbuying.com/item/H96P...OX-374230.html .. and i cant change default launcher and chrome is troubleshooting so i will like to flash rom that can fix that..
    thank you.
    thank you.
    Hi ,
    if you know what Wifichip and DDR chips are used u can try the great Rom of Superceleron .
    Look here :
    but be patient , first look , this PCB where made in different Versions , if you not sure please
    ask there once more , but best is to open and look & upload nice clear Pictures (nearby) .
    good luck / gefattern
      Thank you i will check it. Is there a way to flash it with sd card? And how?
        Hi ,
        yes there is , but best , for flashing , is to follow the Instructions on the first Page ,
        it is not really hard to flash a Box , search for : flashing guide h96pro+ , on big G ,
        always backup your Apps and Data , if needed and wanted , for restore .
