[Firmware Stock] VONTAR Z5 SUPERMAX Amlogic S912 Android TV Box 7.1 2G/16G 2.4G/5GHz Dual WIFI Gigabit
    - Amlogic S912 64 bit Octa core ARM Cortex-A53
    - GPU: ARM Mali-T820MP3 GPU up to 750MHz (DVFS)
    - DDRIII 2GB, eMMC Flash 16GB
    - Android 7.1 OS
    - Support HDR10 and HLG HDR
    - Support VP9 up to 4Kx2K@60fps
    - Support to H.265 HEVC up to 4Kx2K@60fps
    - Max 4Kx2K @60 Resolution
    - 2.4G/5GHz Dual Wifi, Wifi Antenna with Superior Signal Reception
    - Support 1000M Gigabit LAN, Bluetooth 4.0
    - KD Player Pre-installed and Play Perfect
    - Famouse Apps Pre-installed and play perfect.
    - Support Firmware OTA.
    I did make a burn in my micro sd card following this video
    Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
    you can download the burn card maker here
    https://www.multiup.eu/en/mirror/5b9...Card_Maker.exe
    And you can download the iso of the rom 7.1 here
    https://www.multiup.eu/en/mirror/511...5917.V0928.img
    or a zip with all stuff to flash it from usb cable or micro sd card ( use winrar 5 or later to open it)
    Hi KikoLine thanks by your info about it make upgrade this tvbox with this Firmeware .
    The Box seems good as a Beelink Gt1 mini ( same Cpu /Gpu that cust ~60€
    Have you more information about other supliers ( in Europe if possible to NOt paid import taxes ) or Stores in europe to buy Box in that conditions ??
    where can i fund more information to know if is necessary or not make this instalation of this firmware ??
    alternatives and inf about reviews e Benchs of box??
    thanks for you if replay me something
    Joaquim
    if you could send me info in MP send to my [email protected]
